Hyd drive unit question
/ Hyd drive unit question #1
handirifle
Central Coast of CA
Massey Ferguson 1010
If one were to make an Argo type 4 passenger, 6x6, using a small diesel engine and 2 Hyd motors for drive system, could everything be sized (pump, motors etc) and geared to provide a top speed of 20-25 mph?
Seems like hyd drive is the best way to run one of these, to make it steerable.
/ Hyd drive unit question #2
Sure, you just have to match up l the HP, pump displacement hyd motors ,diameters of the tires, and hyd motor torque, etc.
You would probably want one motor per wheel, as in this from Power-Trac.
UV Class
http://power-trac.com/pdf2008/508/UtilityVehicleUV051508.pdf
Two large hyd motors running chains to all the wheels would work also.
Yea the 2 large motor idea was more what I had in mind, that way it would be easier to set the final gearing.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Fuel Tank (A64119)
Fuel Tank (A64119)
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
Caterpillar 214-214B Service Manuals for Excavators (A63117)
Caterpillar...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
