HVAC puzzle
/ HVAC puzzle #31
I contacted the distributor. They build to customer spec'd dimensions, which is perfect.
I received a quote for qty 8. They're $38 each. Hmmmm.............
Cheap and easy - ain't :laughing:
/ HVAC puzzle #32
Here's the project triangle....
Cheap__________Good
Fast
You can only pick two.
If its cheap and good it won't be fast.
If its cheap and fast it won't be good.
If its good and fast it won't be cheap.
Well, you draw the lines, my cheap fast editor is not good! You get the idea. :laughing:
/ HVAC puzzle
Well now that I have all the info I will have to choose between two options, neither of which I will actually use after the initial balancing.
So after taxes, it's $15 or $350
The threshold for this project was $150. After that, the cash disposal mitigation equation must be used.
Based on your project triangle, plus a stomp of common sense, it flattens out to look like this:
easy + cheap = it's not just good, it's good enough.
I'll use nylon washers and locktite on the wing nuts to keep them from becoming a problem.
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Chevrolet...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
1969 Lincoln Continental Mark III Sedan (A59231)
1969 Lincoln...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
light tower (A56857)
