Husqvarna 235
/ Husqvarna 235 #1
Kenneth in Texas
Pretty good ways from DFW, Texas
Kubota L2800 4wd, FEL
small 16" i use for trimming trees and cutting dead limbs that fall. Went to use it last week, its dead, no spark at the plug, surely the ignition which i found for $20 online BUT is there something else I should be checking before I buy one?
/ Husqvarna 235 #2
How 'bout a new plug?:confused3:
/ Husqvarna 235 #3
Check alignment/spacing distance of the coil with the magnets on the flywheel. Not sure about the 235, but sometimes this spacing is adjustable. (Maybe it vibrated to too big of a gap? :confused3: )
/ Husqvarna 235 #5
To rule out the plug, test for spark without the plug. Which can be challenging with only one person unless you have a spark tester.
And if still no spark, flywheel gap as others have suggested. And I would jumper around the switch before I purchased one, just to rule that out.
IF it is none of the above, could be a coil has failed. And depending on how old and condition of the saw, might not be worth messin with.
/ Husqvarna 235
sorry should have said, tried new plug, still nothing. Will try the jumper around the switch. Now what about the flywheel gap? how do i know what the right gap is?
/ Husqvarna 235 #7
For what its worth, rural king lists specs of the saw and they list ignition module air gap at 0.010".
So you need a 10 thousandth feeler gauge.
Rhino HPHD (A64127)
Rhino HPHD (A64127)
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
TAKEUCHI TL12V2 SKID STEER (A65053)
TAKEUCHI TL12V2...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
