Husky 350 stripped threads in head
   / Husky 350 stripped threads in head #11
I have the same problem. Can you tell me what size helicoil you used and where you got it.
Thank You Very Much in advance.
   / Husky 350 stripped threads in head #12
I have a Husqvarna 350. One of the bolts that hold the muffler on came loose and vibrated until the threads stripped in one of the holes. I think my only option is to tap the hole to a larger size.
I believe the original bolts were 10-32. I am wondering if I should go to 12-24 or 1/4-28. What size drill should I use to enlarge the hole before I tap it? Do I need to use helicoil?
Naturally I am concerned about damaging the the head or breaking a tap. Has anyone done this? I inquired at a Husqvarna dealer today and they have never done this before and could not supply me with larger bolts.
Does any one have a solution to keep bolts and screws from vibrating loose?
I stripped 1 of my 350's bolts and retapped it larger but i don't remember what size it was
you can also add a muffler bracket to (help) stabilize the 350's muffler
The chainsaw guy shop talk Repair Husqvarna 350 chainsaw muffler 11 4 - YouTube
uses an additional bolt from the falling spike and the same basic bracket is available on ebay for under $6
hope this helps
   / Husky 350 stripped threads in head #13
Doesn't help at this point. The threads are stripped in the jug. Thanks the bracket may have worked. I silver soldered the bolt heads to the muffler and instead of just coming out it wallowed the hole out.
   / Husky 350 stripped threads in head #14
Well i could pull the bolt out of mine and measure the thread...
As i said- I did re-tap the aluminum Jug bolt boss larger, so I Know it can be done
and the bracket should work with a larger bolt (s) with little or no modification also
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
