Husky 350 stripped threads in head
   / Husky 350 stripped threads in head #11
I have the same problem. Can you tell me what size helicoil you used and where you got it.
Thank You Very Much in advance.
   / Husky 350 stripped threads in head #12
I have a Husqvarna 350. One of the bolts that hold the muffler on came loose and vibrated until the threads stripped in one of the holes. I think my only option is to tap the hole to a larger size.
I believe the original bolts were 10-32. I am wondering if I should go to 12-24 or 1/4-28. What size drill should I use to enlarge the hole before I tap it? Do I need to use helicoil?
Naturally I am concerned about damaging the the head or breaking a tap. Has anyone done this? I inquired at a Husqvarna dealer today and they have never done this before and could not supply me with larger bolts.
Does any one have a solution to keep bolts and screws from vibrating loose?
I stripped 1 of my 350's bolts and retapped it larger but i don't remember what size it was
you can also add a muffler bracket to (help) stabilize the 350's muffler
The chainsaw guy shop talk Repair Husqvarna 350 chainsaw muffler 11 4 - YouTube
uses an additional bolt from the falling spike and the same basic bracket is available on ebay for under $6
hope this helps
   / Husky 350 stripped threads in head #13
Doesn't help at this point. The threads are stripped in the jug. Thanks the bracket may have worked. I silver soldered the bolt heads to the muffler and instead of just coming out it wallowed the hole out.
   / Husky 350 stripped threads in head #14
Well i could pull the bolt out of mine and measure the thread...
As i said- I did re-tap the aluminum Jug bolt boss larger, so I Know it can be done
and the bracket should work with a larger bolt (s) with little or no modification also
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
