Husky 350 stripped threads in head
   / Husky 350 stripped threads in head #11
I have the same problem. Can you tell me what size helicoil you used and where you got it.
Thank You Very Much in advance.
   / Husky 350 stripped threads in head #12
I have a Husqvarna 350. One of the bolts that hold the muffler on came loose and vibrated until the threads stripped in one of the holes. I think my only option is to tap the hole to a larger size.
I believe the original bolts were 10-32. I am wondering if I should go to 12-24 or 1/4-28. What size drill should I use to enlarge the hole before I tap it? Do I need to use helicoil?
Naturally I am concerned about damaging the the head or breaking a tap. Has anyone done this? I inquired at a Husqvarna dealer today and they have never done this before and could not supply me with larger bolts.
Does any one have a solution to keep bolts and screws from vibrating loose?
I stripped 1 of my 350's bolts and retapped it larger but i don't remember what size it was
you can also add a muffler bracket to (help) stabilize the 350's muffler
The chainsaw guy shop talk Repair Husqvarna 350 chainsaw muffler 11 4 - YouTube
uses an additional bolt from the falling spike and the same basic bracket is available on ebay for under $6
hope this helps
   / Husky 350 stripped threads in head #13
Doesn't help at this point. The threads are stripped in the jug. Thanks the bracket may have worked. I silver soldered the bolt heads to the muffler and instead of just coming out it wallowed the hole out.
   / Husky 350 stripped threads in head #14
Well i could pull the bolt out of mine and measure the thread...
As i said- I did re-tap the aluminum Jug bolt boss larger, so I Know it can be done
and the bracket should work with a larger bolt (s) with little or no modification also
2015 FORD F-550 CAB ONLY (A55745)
2015 FORD F-550...
2010 GLOBAL TRI AXLE HAUL TRAILER (A55745)
2010 GLOBAL TRI...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
Scag Mower (A50324)
Scag Mower (A50324)
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
MISC PALLET OF BRAKE DRUMS (A55745)
MISC PALLET OF...
