Husky 350 stripped threads in head
   / Husky 350 stripped threads in head #1
garry
Ohio
JD 1050
I have a Husqvarna 350. One of the bolts that hold the muffler on came loose and vibrated until the threads stripped in one of the holes. I think my only option is to tap the hole to a larger size.
I believe the original bolts were 10-32. I am wondering if I should go to 12-24 or 1/4-28. What size drill should I use to enlarge the hole before I tap it? Do I need to use helicoil?
Naturally I am concerned about damaging the the head or breaking a tap. Has anyone done this? I inquired at a Husqvarna dealer today and they have never done this before and could not supply me with larger bolts.
Does any one have a solution to keep bolts and screws from vibrating loose?
   / Husky 350 stripped threads in head #2
I have never done that before... But I use loctite on all bolts that will be exposed to vibration, you can use the blue one I think Thts the one that can be broken with hand tools but will still protect against vibration
Good luck!
I use loctite on all bolts that will be exposed to vibration, you can use the blue one I think Thts the one that can be broken with hand tools but will still protect against vibration Good luck!
Will loctite hold up on a hot engine?
   / Husky 350 stripped threads in head #4
I haven't had any problems with it yet, and I've run plenty of tanks of gas through my saws with the loctite coming in direct contact with the muffler
   / Husky 350 stripped threads in head #6
how much meat do youhave and what is the head material? aluminum or iron or steel?
if you want to stay oem threads, you could tap for a prass plug, then redrill and tap that back oem.. then again.. 10-32 is darn small.. oversizing to the next standard thread that you can get full root in may bethe least invasive and less hand work..
soundguy
   / Husky 350 stripped threads in head #7
I would do the Helicoil route. If the screw ever comes loose again it's not going to damage the threads like it will with Aluminum.
I went with heli-coil. I never used one before but it was relitively easy.
Thanks for your suggestions.
   / Husky 350 stripped threads in head #9
Check the muffler bolts often, this model is famous for them backing out.
Yes I am finding this out. I was told the 455's also have this problem. It seems to me if a company operates in integrity, they would issue a fix when they discover they have a problem like this.
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
UNUSED INDUSTRIAS AMERICA HI-1100 (A57192)
UNUSED INDUSTRIAS...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2020 PRAT TL (A55758)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
