Husky 350 stripped threads in head
   / Husky 350 stripped threads in head #1
garry
Ohio
JD 1050
I have a Husqvarna 350. One of the bolts that hold the muffler on came loose and vibrated until the threads stripped in one of the holes. I think my only option is to tap the hole to a larger size.
I believe the original bolts were 10-32. I am wondering if I should go to 12-24 or 1/4-28. What size drill should I use to enlarge the hole before I tap it? Do I need to use helicoil?
Naturally I am concerned about damaging the the head or breaking a tap. Has anyone done this? I inquired at a Husqvarna dealer today and they have never done this before and could not supply me with larger bolts.
Does any one have a solution to keep bolts and screws from vibrating loose?
   / Husky 350 stripped threads in head #2
I have never done that before... But I use loctite on all bolts that will be exposed to vibration, you can use the blue one I think Thts the one that can be broken with hand tools but will still protect against vibration
Good luck!
I use loctite on all bolts that will be exposed to vibration, you can use the blue one I think Thts the one that can be broken with hand tools but will still protect against vibration Good luck!
Will loctite hold up on a hot engine?
   / Husky 350 stripped threads in head #4
I haven't had any problems with it yet, and I've run plenty of tanks of gas through my saws with the loctite coming in direct contact with the muffler
   / Husky 350 stripped threads in head #6
how much meat do youhave and what is the head material? aluminum or iron or steel?
if you want to stay oem threads, you could tap for a prass plug, then redrill and tap that back oem.. then again.. 10-32 is darn small.. oversizing to the next standard thread that you can get full root in may bethe least invasive and less hand work..
soundguy
   / Husky 350 stripped threads in head #7
I would do the Helicoil route. If the screw ever comes loose again it's not going to damage the threads like it will with Aluminum.
I went with heli-coil. I never used one before but it was relitively easy.
Thanks for your suggestions.
   / Husky 350 stripped threads in head #9
Check the muffler bolts often, this model is famous for them backing out.
Yes I am finding this out. I was told the 455's also have this problem. It seems to me if a company operates in integrity, they would issue a fix when they discover they have a problem like this.
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2020 HINO 268 26FT NON CDL BOX TRUCK (A56138)
2020 HINO 268 26FT...
2019 Nissan NV200 Cargo Van (A55852)
2019 Nissan NV200...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
