HST pedal creeping - how does this system work?!
   / HST pedal creeping - how does this system work?! #31
I agree with TN8 on the HST Neutral Adjustment....here's what my shop manual says for the NX series tractors. HST Neutral adjust Procedure.JPG
Hope this helps.
What year is your tractor? You might have already said so if you did I apologize. Mine is a 2018
Mine is a 2008. It is disappointing to see them still having this issue on a 2018!
You mean the adjustment of the linkage? Yes, it did not help. As I explained I tried it with all the linkage disconnected to isolate if it is a linkage issue or hydraulic issue. Still tough to tell but the easiest quickest test would be to throw in a stiffer spring. My plan to stack washers behind the spring is effort to mimic that.
   / HST pedal creeping - how does this system work?! #34
I would not think disconnecting the linkage would result in no motion creep. Adjusting the linkage with wheels lifted is performed to find the neutral (no creep) zone.
   / HST pedal creeping - how does this system work?! #35
I agree with TN8 on the HST Neutral Adjustment....here's what my shop manual says for the NX series tractors.View attachment 679406
Hope this helps.
Thank you. I will try this. It creeps much worst when I first start the tractor. I take that is because the fluid is cold and thicker right?
   / HST pedal creeping - how does this system work?! #36
Not sure to be honest. I've not had to do this procedure on my tractor...if it were me, I would do this neutral zone procedure after the tractor's up to operating temp. Good luck, hope you can update us.
   / HST pedal creeping - how does this system work?! #37
Sorry to resurrect an old thread but I just had this exact problem and repaired it today. I picked up a used 2016 ck2510 with low hours (370) and you could never get the machine to sit in one spot short of tapping the fwd and rev pedals constantly. I found the set bolt on the hst arm to be slightly loose. After backing off the lower nut and tightening the set bolt tighter, the machine snaps back to neutral and stays there with zero creep. Hope this helps someone else as it's a difficult problem to live with.
   / HST pedal creeping - how does this system work?! #38
Good job! Thanks for sharing this information (right way to resurrect an old thread).
   / HST pedal creeping - how does this system work?! #39
Thanks! I printed and will keep in my file of future fixes should the problem arise.
MoKelly
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2016 John Deere 326E (A47477)
2016 John Deere...
BRADCO HP600 COLD PLANER (A52707)
BRADCO HP600 COLD...
