Hrdraulic toplink
/ Hrdraulic toplink #1
Farmert22
Wv
Nh55
Hey everybody I bought a hyrdaulic toplink with the anti creep valve and when i lift its fine but when it retracts it make a squeaking noise and is kind of jerky. It this because of the creep valve or it just need seals to be broke in? I cycled the valve a bunch of times to try and bleed air out of it but it still does it. Its working fine but just curious about this?
/ Hrdraulic toplink #2
My top link with check valves is smooth as silk, and no noise. I think you've a funky check valve.
/ Hrdraulic toplink
Whats the benefit to the check valve? I know they supposedly stop creep but I wouldnt think it would really creep that much. Opinion?
/ Hrdraulic toplink #4
With a load on the top link oil can leak past the spool on the directional valve on tractor. How much the link moves deends on factors like load, oil temperature, directional valve quality / leakage rate. The check valves prevent this from happening.
/ Hrdraulic toplink #5
I have a top link with check valves. Works smooth and quiet.
2017 Case CX145D (A60462)
2017 Case CX145D...
PRENTICE 2384C LOG LOADER (A64276)
PRENTICE 2384C LOG...
42" X 27" FIRE PIT RING/DISC (A64281)
42" X 27" FIRE PIT...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2022 EZ-GO ELITE...
