Hrdraulic toplink
/ Hrdraulic toplink #1
Farmert22
Wv
Nh55
Hey everybody I bought a hyrdaulic toplink with the anti creep valve and when i lift its fine but when it retracts it make a squeaking noise and is kind of jerky. It this because of the creep valve or it just need seals to be broke in? I cycled the valve a bunch of times to try and bleed air out of it but it still does it. Its working fine but just curious about this?
/ Hrdraulic toplink #2
My top link with check valves is smooth as silk, and no noise. I think you've a funky check valve.
/ Hrdraulic toplink
Whats the benefit to the check valve? I know they supposedly stop creep but I wouldnt think it would really creep that much. Opinion?
/ Hrdraulic toplink #4
With a load on the top link oil can leak past the spool on the directional valve on tractor. How much the link moves deends on factors like load, oil temperature, directional valve quality / leakage rate. The check valves prevent this from happening.
/ Hrdraulic toplink #5
I have a top link with check valves. Works smooth and quiet.
2000 PETERBILT 378(INOPERABLE) (A67714)
2000 PETERBILT...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
2015 INTERNATIONAL PROSTAR+ (A67714)
2015 INTERNATIONAL...
2018 Mitsubishi Eclipse SUV (A66738)
2018 Mitsubishi...
