hp ratings ?
/ hp ratings ? #21
When a manufacturer builds a product, he rates the max horsepower for the PTO as a guaranteed horsepower. The product itself will probably withstand a lot more than that, but the precentage of break damage goes up. When you buy a strap rated at 3000 pounds, the manufacturer guantees that the strap will move 3000 pounds, but it is usually tested at much higher weight, usually 100% more, maybe 6000 pounds before the strap will break.
A shear pin is usually put in a drive train where it does not have a slip clutch. The pin is a expendable or wear item that protects the equipment gear box and tractor PTO from being damaged by sudden shocks in the drive train. That is why they make grade #2 bolts, also. It is a protection device installed in the system. It is a expendable item. I would rather replace a $.40 bolt and nut than replace a $400.00 gear box, anyday.
/ hp ratings ? #22
Another HP question: Ive seen spec sheets w/ the tractors engine net & gross hp and PTO hp ratings. I dont undestand why the engine hp is given in terms of 2 ratings (net and gross).
/ hp ratings ? #23
I am not positive, but I think the gross hp ratings would be the power developed with the engine not installed in the tractor and not powering accessories like alternator, hydraulic pump, etc. while the net hp rating applies to the installed engine running the accessories. You have a good question that I can't really answer, what IS the purpose of a gross hp. rating? For comparison purposes? Anybody else know that one?
/ hp ratings ? #24
You must have some really big gophers, I have hit huge anthills on my property that were a foot high and a foot across with my bush hog and still have not broken a shear pin yet. YET.
/ hp ratings ? #25
(net and gross).
This is sorta like your income. What you think you make and whats left over after everyone takes thier share.
Egon
/ hp ratings ? #26
Let's see now, gross income is what you earn, net income is what you have after everyone takes their share, that makes sense to me.
So after my wife gets HER cut of what's left, that means I end up with pto income...... right ? /forums/images/graemlins/confused.gif
/ hp ratings ? #27
OK, but why would you spec both?
/ hp ratings ? #28
</font><font color="blue" class="small">( Another HP question: Ive seen spec sheets w/ the tractors engine net & gross hp and PTO hp ratings. I dont undestand why the engine hp is given in terms of 2 ratings (net and gross). )</font>
I don't know what are meant by gross and net hp /forums/images/graemlins/smirk.gif Maybe, gross hp is hp including the package? /forums/images/graemlins/cool.gif
Seriously. Maybe, we should ask another (related) question.
When it's said "Engine HP" exactly at what point of the engine is that "Engine HP" measured and given in the tractor manual? Is it at the crank? At the tires? In the combustion chamber? Where? If we answer this, we can answer net and gross HPs.
Ps: you know the point of pto HP and can measure that HP yourself easily - But how do you measure Engine HP? (assume you lost the manual or your tractor is old or you don't believe tractor mfg.)
/ hp ratings ? #29
Yes, exactly. Its rather like electric motor hp ratings on power tools. Certain mfgs inflate motor hp rating to the point where its meaningless.
Its completely unclear (to me) why an end user would care what the diff between gross and net is. I might want to know net and certainly PTO but gross would only tell me how much auxillary systems are sucking off. Only a very few of those systems could the end user effect (like turning off the AC). Im sure Im missing something obvious here...so humor me...OK?
/ hp ratings ? #30
I used to have lots of them on the property.. but after I got rid of the cactus on the property... they all left. Sometimes the dirt mounds will be 1' tall.. and a cople feet across. A single mount doesn't pop it... a day of mowing would though.
Annoying as it is.. I'm mowing with the same shear bolt from last year ( didn't break it ).. but it is actually half way cut... so I can't back it out and change it.. I just have to wait till it pops to chage it... oh well..
Soundguy
Hey to add to that net / gross discussion.. how about rated HP
/ hp ratings ? #31
The real question is whether they mean SAE gross and SAE net hp or something else. Both reference the hp at the flywheel. SAE gross hp (which was the common advertised hp for cars before '71 I think) is essentially the engine with only the absolute bare minimum of components to make it run, ie just about the most hp you can squeeze out of it. SAE net is with all accessories, exhaust, etc...that the engine would have attached to in the vehicle minus the actual drivetrain.
Since net hp varies due to differences in accessories, the type of exhaust, etc.. the gross hp is a valuable figure. If for instance you want to change or add accessories, gross would be the baseline you subtracted them from. PTO hp is the hp available at the pto shaft. This obviously changes a little as you change the net hp.
Now like I stated before, I don't know if they are refering to SAE hp or not.
/ hp ratings ? #32
There are 3 horsepower ratings to distinguish. The SAE defines 2 tests--one dealing with "gross" and one dealing with "net." Both are done in a test cell with an engine alone powering a dynomometer. It is not installed in a tractor or other vehicle.
In the "gross hp" test, all accessories including the radiator, fan, and other cooling system components and all exhaust components are removed. In addition there are also no pumps, etc. These effects are all supplied externally to the engine so that it's own power is not used to support them. Power is measured by the dynamometer at the flywheel. The resulting "gross horsepower" is a somewhat high number and rather meaningless except for advertising purposes. Almost all tractors below 40 PTO hp are advertised on the basis of Gross HP.
SAE "net HP" is the same type of test but the essential cooling system and exhaust system components are in place. Still no hydraulic pumps. Again the dyno measures this power at the flywheel.
When the engine is installed in a tractor the most meaningful measure of power is PTO hp. This is again measured with a dynomometer, but it is now connected to the PTO on the tractor if it has one (some large articulated 4WD tractors do not so their HP is normally quoted as Flywheel HP or Net HP). Note that the tractor is not moving and things like the air conditioner are shut off. As a general rule of thumb, PTO HP is approximately 85% of Net or Flywheel HP.
Now if the transmission is hydrostatic, the PTO HP will be slightly lower than if there is a gear transmission. This is because the hydro pump runs all of the time, so even though the tractor is not moving in the PTO-HP test, some power is consumed by the hydro pump. Usually PTO-HP with a hydrostatic tractor is about 83% of Net HP.
So why do manufacturers use "gross hp?" It is primarily for advertising purposes so that the largest possible legitimate number can be quoted.
The most reasonable way to compare tractors on the basis of horsepower is to look strictly at PTO hp. Keep in mind that this hp is what is measured at the PTO with the tractor stationary.
Sometimes you hear "drawbar" hp mentioned. This can be measured by measuring the horizontal drawbar pull and tractor true ground speed. A tractor pulling on concrete, might get as much as 85% of the net engine hp out at the drawbar. On softer soils it can usually be in the 70% range at best. Therefore, drawbar hp is not usually quoted in advertising.
This may be more than you wanted to know. If so, I apologize.
JackIL
/ hp ratings ? #33
Thats great...thanks for all the info. Its as I thought though, gross hp is just a window dressing number which is mostly meaningless.
/ hp ratings ? #34
Maybe, Gross HP is being written in user manuals/etc of tractors because the engine MFGs maybe wanting that in their contracts with the tractor MFGs. You know manufacturers of tractors and manufacturers of their engines aren't always same companies.
/ hp ratings ? #35
Excellent post with useful information, I was beginning to wonder what drawbar hp meant and you explained it. Thanks.
Kubota L175 Tractor (A62613)
Kubota L175...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
John Deere 637 (A64126)
John Deere 637...
