Tractor Sizing HP Advice
/ HP Advice #51
I would never recommend anyone back down a hill with a load, most people have a hard enough time backing up, get a load pushing you drop a tire in a hole or hit a rock, or the front end starts to come around. Just gear down start down with the load low and be ready to put your bucket down into the dirt if need be, you are much more in control driving forward then backing up. And if it gets out of control backing you have lost it, forward you may ride it out.
You do what you want but the proper procedure is to keep the load on the upside of the hill! the tractor is more stable and the weight on the front isn't overloading the front axel when doing it proper. If your still not able to control it due to wet slippy/muddy ground then you already did something else wrong like didn't chain up or went down a hill you shouldn't have to begin with.
I have fired operators who thought they knew better after they destroyed things and cost me money but the funny thing is those who listened and did it the right way never cost me a cent.
/ HP Advice #52
i'm with paul on the one. i was taught to back down if you get in trouble you can drop the loader and it will straighten you out if need be. i had a large poplar limb in my grapple and i felt very much in control backing down the hill. i don't feel very in control driving down the same hill empty
In most cases it will straighten you out, act as a break and the likelihood of getting sideways with two tires in the air is reduced greatly.
I once watched a guy going down forward get the rear up. He dropped the bucket a little too hard caught an uneven spot on the hill and set the machine sideways as it didn't grab the hole bucket. He ended up rolling all the way to the bottom destroying my very expensive machine. what I don't understand is we worked the job for 6 months after I fired him and no one lost it going down the same hill with any of the other machines. Yes we had some slides and buckets down when it rained but we didn't have any more damage, injuries or anything that one would even remotely call close.
Last year my neighbor did the same thing going down forward on his steep drive only to end up rolling his Kubota into the ditch. I have been running threw there for longer than he has been alive and always turn around and back down when any substantial weight is up front and haven't lost control once.
Lets not forget how much weight we transfer to the front axel when we go down forward with a load, is it rated for it? its honestly just a matter of time till it breaks faster than one can lower the bucket and you end up in a roll scenario.
SO let him go down forward all he wants I will send flowers to the funeral parlor when he finds the weak link in his hypothesis!
/ HP Advice #53
Tomire , when purchasing your tractor get adjustable rims and set them to the widest practical width for your operation. You will find that a modest increase in width makes a big difference in sideways stability.
Whichever way you jump for the backhoe, consider a "pick" (single leg ripper) to break the ground or loosen rocks and stumps. It will beat using a small bucket in most cases. Also I have found that a pick is great for breaking stumps into smaller sections for ease of handling.
Good luck.
/ HP Advice #54
After all the "do this....do that" in this thread, plus the fact that you already decided what to get,,,a couple of things stand out that hardly anyone mentioned...suggest you get R1 Ag tires...they'll handle better and last longer and have them loaded when you buy the tractor. Bunch of folks will say get "beet juice"...personally, I use methanol (most tractor places do and its the most economical of the possibilities). Bunch of folks say get the HST...so be it...but I prefer 8 or 12 speed shuttle...with syncro gears. Especially if you ever decide to use any REAL ground engaging stuff....also I've got the Backhoe as well...I haven't put it on in a couple of years, but if the $$ doesn't bother you get it with the tractor and have the dealer put it on before you buy...(the real issue is the subframe...I did it myself with the help of a couple of friends...and a good impact wrench...). Anyhow... good luck. PS: I'll probably get flamed for taking the contrarian view on most everything, but most of what you are gonna do, I've been there///done that. BobG in VA
/ HP Advice #55
YOU HAVE YOUR METHOD THAT SUPPOSEDLY WORKS FOR YOU
I will run my equipment my way you run yours any way you want, I have a feeling I have worked more hills then you will ever.
Lou
/ HP Advice #56
Tractor Mike says back down the hill....
You fellas need to keep an open mind, listen to what people are saying and why, analyze the data, and make a smart decision. Sometimes, just because you've been doing something for a long time, and maybe your dad and your grandpa did the same thing, it might be time to re-think it. Watch what this fella shows, and listen to what he says and why. It makes good sense. ;)
/ HP Advice #57
OK. I have lots of hills that I drive my CUT on.
After a couple of hairy rides (you never learn the first time) I always now go down hill in 4 wheel drive.
Reason being that the rears are relatively light and the fronts (most CUT's) do not have brakes so the rears brakes simply are not effective.
In 4 wheel drive the engine compression is your friend.
Failing all that you simply drop your FEL and pray.
LOL, for a wild ride fill the FEL and drive down a steep hill in 2 WD, (wilder ride than an amusement park rollercoaster.)
/ HP Advice #58
Never done that but I bet you are right!!!! That would be rather exciting....
/ HP Advice
Hills and wild rides are why I'm getting out of my Ford 8n. Dropped out of gear once too often for me. I always had a bailout plan (I'd cut the flat area at the bottom of the hill so I could see where to go) and never really in danger but yep quite a wild ride alright!
/ HP Advice #60
Lou
At My age and the amount of years I have run my business I would doubt you have even been alive half as long as I.
Its not my method, its the way any reputable training program anyplace in the world would teach safe operation of which I had a big part in for many years.
2005 Ford Freestar Van (A59231)
2005 Ford Freestar...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
2015 John Deere Z950M 72in Zero Turn Mower (A59228)
2015 John Deere...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
Pair of 2001 XA800Z Yamaha Jet Skis (A61166)
Pair of 2001...
1991 International 4900 Box Truck (A55315)
1991 International...
