How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #61
   / How Would You As A TBNer Cut A Metal Coffee Can? #62
Rather than freezing the CC simply put in the microwave oven for a few mins and that'll curtail spending urges.
(will take a few days 4 a replacement to arrive, LOL)
   / How Would You As A TBNer Cut A Metal Coffee Can? #63
Cut out bottom with can opener, run over can with tractor to flatten then cut in half with tin snips. Problem solved!
   / How Would You As A TBNer Cut A Metal Coffee Can? #64
I like it :thumbsup:
Tin snips? Or a multi-ton metal press/shear? Then 'reinflate' the can to the original round shape. Not sure how to eliminate the creases from flattening though. Maybe a planishing hammer?
I did't want to cut below the rim. I wanted both end rims intact and then cut in the middle leaving two halves, each with one open end and one rimmed end.
   / How Would You As A TBNer Cut A Metal Coffee Can? #68
Give it to a 12 yr old boy and let him do it!
   / How Would You As A TBNer Cut A Metal Coffee Can? #70
For a job like that I would use a little cut off wheel driven by my air compressor. Dremel would work, too.
2017 Chevrolet Colorado Crew Cab Pickup Truck (A55788)
2017 Chevrolet...
1988 John Deere 4250 (A53314)
1988 John Deere...
UNUSED Hydraulic Thumb Attachment (A47477)
UNUSED Hydraulic...
2016 Ford LCF Stake Body (A47477)
2016 Ford LCF...
SLIDE MASTER ALUMINUM SLIDES (A54757)
SLIDE MASTER...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
