How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #61
   / How Would You As A TBNer Cut A Metal Coffee Can? #62
Rather than freezing the CC simply put in the microwave oven for a few mins and that'll curtail spending urges.
(will take a few days 4 a replacement to arrive, LOL)
   / How Would You As A TBNer Cut A Metal Coffee Can? #63
Cut out bottom with can opener, run over can with tractor to flatten then cut in half with tin snips. Problem solved!
   / How Would You As A TBNer Cut A Metal Coffee Can? #64
I like it :thumbsup:
Tin snips? Or a multi-ton metal press/shear? Then 'reinflate' the can to the original round shape. Not sure how to eliminate the creases from flattening though. Maybe a planishing hammer?
I did't want to cut below the rim. I wanted both end rims intact and then cut in the middle leaving two halves, each with one open end and one rimmed end.
   / How Would You As A TBNer Cut A Metal Coffee Can? #68
Give it to a 12 yr old boy and let him do it!
   / How Would You As A TBNer Cut A Metal Coffee Can? #70
For a job like that I would use a little cut off wheel driven by my air compressor. Dremel would work, too.
2014 JCB 930 (A53317)
New/Unused 8 Piece CFG Industrial Mini Excavator Attachment Set (A57454)
New/Unused 8 Piece...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
