How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #51
I’m not getting the point?
You said it would split the can? Tin will give, pipe will not. Maybe we are thinking 2 different things.
I'm thinking of a large tin coffee can that has had the lid removed by a can opener. The large cans used to have indented bands around the circumference. 2 of them.
   / How Would You As A TBNer Cut A Metal Coffee Can? #52
But why freeze the CC at the bottom?
   / How Would You As A TBNer Cut A Metal Coffee Can? #55
If you have to freeze your cc in a coffee can maybe you should come up with a better payment plan.
   / How Would You As A TBNer Cut A Metal Coffee Can? #56
How about use a pipe cutter?
   / How Would You As A TBNer Cut A Metal Coffee Can? #58
When this started I feared that it would be one of those questions which never got answered. Thank you for telling us how you did it!
   / How Would You As A TBNer Cut A Metal Coffee Can? #60
Folgers, MJB or?
2018 Vermeer BC700XL Woodchipper (A57453)
2018 Vermeer...
Electric Utility Cart (A56857)
Electric Utility...
1996 Ford F Series Distribution Truck (A55272)
1996 Ford F Series...
John Deere 1025R (A53317)
John Deere 1025R...
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
