How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #51
I’m not getting the point?
You said it would split the can? Tin will give, pipe will not. Maybe we are thinking 2 different things.
I'm thinking of a large tin coffee can that has had the lid removed by a can opener. The large cans used to have indented bands around the circumference. 2 of them.
   / How Would You As A TBNer Cut A Metal Coffee Can? #52
But why freeze the CC at the bottom?
   / How Would You As A TBNer Cut A Metal Coffee Can? #55
If you have to freeze your cc in a coffee can maybe you should come up with a better payment plan.
   / How Would You As A TBNer Cut A Metal Coffee Can? #56
How about use a pipe cutter?
   / How Would You As A TBNer Cut A Metal Coffee Can? #58
When this started I feared that it would be one of those questions which never got answered. Thank you for telling us how you did it!
   / How Would You As A TBNer Cut A Metal Coffee Can? #60
Folgers, MJB or?
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
KING KUTTER SCOOP PAN (A52708)
KING KUTTER SCOOP...
NEW HOLLAND 644 SILAGE SPECIAL ROUND BALER (A52708)
NEW HOLLAND 644...
BEFCO 10 WHEEL V-RAKE (A52708)
BEFCO 10 WHEEL...
1994 International 3800 Bus (A54814)
1994 International...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
