How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #31
I've found that the best tool I have to cut any sort of metal is the 15 amp Skill saw with a metal blade. I usually just use cheap disintegrating blades, of course much fancier options are available.
1. Put can in vice length wise and cut one side of can
2. spin can 180 degrees and cut other side.
Takes a few seconds and most of that will be positioning the coffee can.
I needed both halves intact, but without the ends. No flattening and tin snips and nibbles leave too much waste in my past experience.
The frozen ice filled idea was cool though.
The first response would have been better combined with the drill press one if it used a .22, but that would have taken a lot more set-up with backdrops and all and a lot better aim than I've ever had.
   / How Would You As A TBNer Cut A Metal Coffee Can? #34
   / How Would You As A TBNer Cut A Metal Coffee Can? #35
Try det cord...
   / How Would You As A TBNer Cut A Metal Coffee Can? #36
I use these for tin and roofing. https://images.homedepot-static.com.../svn/dewalt-nibblers-shears-dw890-64_1000.jpg
   / How Would You As A TBNer Cut A Metal Coffee Can? #39
   / How Would You As A TBNer Cut A Metal Coffee Can? #40
I would use a device that emits a bright beam of narrow light; we call it a "LASER" A.P.
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
2023 Load Trailer (A55787)
2023 Load Trailer...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
