How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #11
A little cut off wheel on a dremel or die grinder would work.
How about a nibbler?
   / How Would You As A TBNer Cut A Metal Coffee Can? #12
Maybe make a wooden plug to slip inside the can and chuck it in a lathe like others have mentioned. Then use a small pipe cutter wheel in the tool rest to part it.
Is this a standard can with crimped bottom and top ?
I use a can opener for my metal cans when need some thin metal.
Typical coffee can, standard bottom and a rolled rim for the top with a foil vacuum seal. Bottom is still in thinking it might help stabilize it for cutting. I think I have a cutoff wheel for a RotoZip with a flex shaft.
So, no Lasers or high pressure plasma streams? ;-)
   / How Would You As A TBNer Cut A Metal Coffee Can? #14
I like this idea and would be quick. I looked all through my shop but couldn’t find a coffee can to try.
Just bags these days
   / How Would You As A TBNer Cut A Metal Coffee Can? #15
Rube Goldberg style: put the marble in the trough which rolls down to ring a bell, startling the rat in the hamster wheel. The hamster wheel winds up a string which tips the teeter totter, pouring water from the pitcher to fill the glass of water. The monkey picks up the glass of water to take a sip, and the glass is tied to a string which pulls a light switch up, closing the circuit that my angle grinder is plugged into so I can cut the coffee can in half.
Angle grinder. Or maybe a Dremel tool if it's ornate.
   / How Would You As A TBNer Cut A Metal Coffee Can? #16
Put a baggie full of water in it and freeze it solid then stick it in the bandsaw.
   / How Would You As A TBNer Cut A Metal Coffee Can? #18
Thin cutoff wheel or band saw are by far the simplest and fastest but another option might be a chain type tubing cutter...
or find a can that is already the right depth and use a regular can opener to cut the ends out...!
   / How Would You As A TBNer Cut A Metal Coffee Can? #19
I'm just surprised you found a metal coffee can. Everything is plastic these days.
^^ Some of the off brands still use them. Aldis does for a couple of grinds.
I went old school though and used a fine tooth jigsaw blade. No snagging or tearing, but I did have to run the edge over a grinder to deburr it.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
2018 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2018 INTERNATIONAL...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2010 Volvo XC90 SUV (A56859)
2010 Volvo XC90...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
