How Would You As A TBNer Cut A Metal Coffee Can?
   / How Would You As A TBNer Cut A Metal Coffee Can? #11
A little cut off wheel on a dremel or die grinder would work.
How about a nibbler?
   / How Would You As A TBNer Cut A Metal Coffee Can? #12
Maybe make a wooden plug to slip inside the can and chuck it in a lathe like others have mentioned. Then use a small pipe cutter wheel in the tool rest to part it.
Is this a standard can with crimped bottom and top ?
I use a can opener for my metal cans when need some thin metal.
Typical coffee can, standard bottom and a rolled rim for the top with a foil vacuum seal. Bottom is still in thinking it might help stabilize it for cutting. I think I have a cutoff wheel for a RotoZip with a flex shaft.
So, no Lasers or high pressure plasma streams? ;-)
   / How Would You As A TBNer Cut A Metal Coffee Can? #14
I like this idea and would be quick. I looked all through my shop but couldn’t find a coffee can to try.
Just bags these days
   / How Would You As A TBNer Cut A Metal Coffee Can? #15
Rube Goldberg style: put the marble in the trough which rolls down to ring a bell, startling the rat in the hamster wheel. The hamster wheel winds up a string which tips the teeter totter, pouring water from the pitcher to fill the glass of water. The monkey picks up the glass of water to take a sip, and the glass is tied to a string which pulls a light switch up, closing the circuit that my angle grinder is plugged into so I can cut the coffee can in half.
Angle grinder. Or maybe a Dremel tool if it's ornate.
   / How Would You As A TBNer Cut A Metal Coffee Can? #16
Put a baggie full of water in it and freeze it solid then stick it in the bandsaw.
   / How Would You As A TBNer Cut A Metal Coffee Can? #18
Thin cutoff wheel or band saw are by far the simplest and fastest but another option might be a chain type tubing cutter...
or find a can that is already the right depth and use a regular can opener to cut the ends out...!
   / How Would You As A TBNer Cut A Metal Coffee Can? #19
I'm just surprised you found a metal coffee can. Everything is plastic these days.
^^ Some of the off brands still use them. Aldis does for a couple of grinds.
I went old school though and used a fine tooth jigsaw blade. No snagging or tearing, but I did have to run the edge over a grinder to deburr it.
2022 Toro Z-Master 5000 Series 52in Zero-Turn Commercial Mower (A56857)
2022 Toro Z-Master...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
John Deere 5075E (A53317)
John Deere 5075E...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2019 Isuzu NRR 1,200 Gallon Fuel Transport Truck (A56858)
2019 Isuzu NRR...
2012 FREIGHTLINER M2 FLATBED (A58214)
2012 FREIGHTLINER...
