How wide is a 2013 CK30HST with IND tires?
   / How wide is a 2013 CK30HST with IND tires? #1
rockhntr
Cincinnati, OH
Kioti CK30 HST
What is the total rear width of a 2013 CK30HST with IND tires?
I want to buy attachments wider than the rear tire footprint.
   / How wide is a 2013 CK30HST with IND tires? #2
Book says 54.6"
   / How wide is a 2013 CK30HST with IND tires? #3
Typically people get 60" implements to cover their tracks on this size tractor. You said that you want to go wider, so 66" & 72" implements are what you want to be looking for. For rear blades & landscape rakes, you would be looking at 7 footers. ;)
   / How wide is a 2013 CK30HST with IND tires? #4
Your bio says you have a CK30, why dont you just measure the width across the tires. Then you'll be sure. :thumbsup:
I have a 68" snowblower and it cleaned about 4" - 5" outside the tires on each side (of my CK25).
Thanks for the input. I do own a CK30HST, just couldn't measure myself since it's at our other property at the moment.
I only have 8 hours on it right now, so there's a lot to learn.
   / How wide is a 2013 CK30HST with IND tires? #6
rockhntr
My CK27 with R4 Ind Tires measures 61 inches tread width (outside of tread to outside of tread - rear tires at outside diameter of the tires). The tire width at tire mid-section by about 1 and 1/2 inches wider per side, so overall width at the rear tires widest section is approx 64 inches (this is also the widest section of the tractor).
I believe the CK27 has the same R4 tires that are on the CK30 and CK35.
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2012 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2012 FREIGHTLINER...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
