How wide is a 2013 CK30HST with IND tires?
   / How wide is a 2013 CK30HST with IND tires? #1
rockhntr
Cincinnati, OH
Kioti CK30 HST
What is the total rear width of a 2013 CK30HST with IND tires?
I want to buy attachments wider than the rear tire footprint.
   / How wide is a 2013 CK30HST with IND tires? #2
Book says 54.6"
   / How wide is a 2013 CK30HST with IND tires? #3
Typically people get 60" implements to cover their tracks on this size tractor. You said that you want to go wider, so 66" & 72" implements are what you want to be looking for. For rear blades & landscape rakes, you would be looking at 7 footers. ;)
   / How wide is a 2013 CK30HST with IND tires? #4
Your bio says you have a CK30, why dont you just measure the width across the tires. Then you'll be sure. :thumbsup:
I have a 68" snowblower and it cleaned about 4" - 5" outside the tires on each side (of my CK25).
Thanks for the input. I do own a CK30HST, just couldn't measure myself since it's at our other property at the moment.
I only have 8 hours on it right now, so there's a lot to learn.
   / How wide is a 2013 CK30HST with IND tires? #6
rockhntr
My CK27 with R4 Ind Tires measures 61 inches tread width (outside of tread to outside of tread - rear tires at outside diameter of the tires). The tire width at tire mid-section by about 1 and 1/2 inches wider per side, so overall width at the rear tires widest section is approx 64 inches (this is also the widest section of the tractor).
I believe the CK27 has the same R4 tires that are on the CK30 and CK35.
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2014 JCB 930 (A53317)
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
