How wide is a 2013 CK30HST with IND tires?
   / How wide is a 2013 CK30HST with IND tires? #1
rockhntr
Cincinnati, OH
Kioti CK30 HST
What is the total rear width of a 2013 CK30HST with IND tires?
I want to buy attachments wider than the rear tire footprint.
   / How wide is a 2013 CK30HST with IND tires? #2
Book says 54.6"
   / How wide is a 2013 CK30HST with IND tires? #3
Typically people get 60" implements to cover their tracks on this size tractor. You said that you want to go wider, so 66" & 72" implements are what you want to be looking for. For rear blades & landscape rakes, you would be looking at 7 footers. ;)
   / How wide is a 2013 CK30HST with IND tires? #4
Your bio says you have a CK30, why dont you just measure the width across the tires. Then you'll be sure. :thumbsup:
I have a 68" snowblower and it cleaned about 4" - 5" outside the tires on each side (of my CK25).
Thanks for the input. I do own a CK30HST, just couldn't measure myself since it's at our other property at the moment.
I only have 8 hours on it right now, so there's a lot to learn.
   / How wide is a 2013 CK30HST with IND tires? #6
rockhntr
My CK27 with R4 Ind Tires measures 61 inches tread width (outside of tread to outside of tread - rear tires at outside diameter of the tires). The tire width at tire mid-section by about 1 and 1/2 inches wider per side, so overall width at the rear tires widest section is approx 64 inches (this is also the widest section of the tractor).
I believe the CK27 has the same R4 tires that are on the CK30 and CK35.
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
SET 60'' FORKS (A56857)
SET 60'' FORKS...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
