How to weld copper?
/ How to weld copper? #31
I would solder with lead free solder inasmuch as it is decorative only and is not subject to pressure stress (copper plumbing or HVAC lines). While I am no professional, I have soldered plenty of copper plumbing with acid core. If you manage the heat properly, the solder all but disappears into the joint. I have also used solder paste for solder joints. Either wire solder or paste solder works well and leaves little visible excess solder at the joint interface. I once soldered a leaking copper HVAC line on my motorhome roof mounted A/C unit (R22). It never leaked thereafter. Unless the job is electrical (completely different animal), I have always used a propane torch. They provide more than adequate heat.
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
LMC Ag 300 Gallon 54' Boom Sprayer (A60462)
LMC Ag 300 Gallon...
John Deere 5103 (A53317)
John Deere 5103...
2021 CATERPILLAR 300.9D MINI EXCAVATOR (A62129)
2021 CATERPILLAR...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
