How to trace a leak, Kymron ZX22
   / How to trace a leak, Kymron ZX22 #1
Jrasband
Platinum Member
Southwest VA
Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
My Kymron ZX22 has a hydraulic fluid leak that is baffling me.
I have removed most of the panels and washed everything down with degreaser multiple times. I parked the machine on level ground. I have been able to narrow down the area of the leak to but still am unable to find it. The leak is located under the floor board on the right side, buried underneath all of the hoses in the picture, and is leaking when parked. The oil is pooling on the plate underneath the hoses.
What else can I do to trace this leak? I think I need a inspection mirror as I am not able to look at the underside of where the leak is. The area is basically walled off on the sides as well so I am just able to look from above.
   / How to trace a leak, Kymron ZX22 #3
They make a dye you can add and it shows up with a black light, might help.
What he said (y)
You can get a kit online or at napa, autozone, etc... I've used it quite successfully in both engine and hydraulic leaks as well as a radiator leak. They make different dyes for different systems.
To make it easier on yourself, clean everything as well as possible. Add the dye. Run the machine for a while, then if you can, park in a garage or barn. Do it in the evening so it'll make it easier to detect the leak with the black light.
Good luck. :)
   / How to trace a leak, Kymron ZX22 #4
If you are saying that the area suspected of leaking cant be visually seen because of lack of access, what other options are there besides an inspection mirror or USB inspection camera? I would think an inspection mirror would be the easist and least expensive option to try first.
Yes that is what I was saying. I was wondering if there was a way of finding the leak that I didn't know about that's why I asked. I am going to start with the inspection mirror.
   / How to trace a leak, Kymron ZX22 #6
You might search or ask on the chinese mini forum on fb if there is some kind of common leak in a particular spot on your machine. Like some say the O ring on the pump hose has been crushed on some models of minis…not saying yours…just a possible example.
The other challenge is figuring out the source of the leak when things are already soaked. Sometimes must clean it up and then look.
   / How to trace a leak, Kymron ZX22 #7
Check tightness of all fittings before beginning to spend money. Things like that just pop into a penny-pinchers head.
I might have to become a nickel-pincher in the future.
I found the leak, it was a loose hose clamp. There is a rubber hose which connects the intercooler to the hard line and the clamp on the hard line side was leaking. I moved the clamp closer to the end of the hose and added a second clamp.
Thanks for everyone's help. It was the inspection mirror would allowed me to find the leak.
   / How to trace a leak, Kymron ZX22 #9
Glad you figured it out, if you didn’t know there is a Kymron owners FB group. I have a YH 14
thanks, I did not know that!
   / How to trace a leak, Kymron ZX22 #11
I think there are getting to be enough owners of chinese minis on TBN that they should have their own forum on TBN. Maybe not enough owners to have brand specific forums yet, but a general forum?
Yeah I think it is a good idea. I would much rather talk on here then Facebook! Also, the Facebook for Kymron is run by one of the Kymron dealers and you can only talk Kymron and only positive...
Update. I used the machine for a hour after fixing the hydraulic leak, the next morning I went out to feel for oil. Now the machine is leaking diesel from the tank, turns out the tank is prone to cracking the dealer said. I told the dealer I am not surprised at all because the tank is only mounted on the bottom. When I drive on a gravel road in high speed the tank shakes back and forth, prob a inch each direction! Turns out the tank is not covered under warranty.... New machine 150 hours!
So I have to fix another leak and fabricate something so the tank is more supported.
   / How to trace a leak, Kymron ZX22 #14
I pressurize mine with air once. Then used soap in a spray gun. Very effective although difficult to set up
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2002 International 9200i Truck (A61306)
2002 International...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
Deere 310SK (A57148)
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
HUSTLER RAPTOR SD ZERO TURN LAWNMOWER (A60430)
HUSTLER RAPTOR SD...
