Jrasband
- Joined
- Dec 31, 2021
- Messages
- 668
- Location
- Southwest VA
- Tractor
- Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
My Kymron ZX22 has a hydraulic fluid leak that is baffling me.
I have removed most of the panels and washed everything down with degreaser multiple times. I parked the machine on level ground. I have been able to narrow down the area of the leak to but still am unable to find it. The leak is located under the floor board on the right side, buried underneath all of the hoses in the picture, and is leaking when parked. The oil is pooling on the plate underneath the hoses.
What else can I do to trace this leak? I think I need a inspection mirror as I am not able to look at the underside of where the leak is. The area is basically walled off on the sides as well so I am just able to look from above.
