How to start HST
/ How to start HST #1
Waffles
SLO, CA
MT225HE
My manual says to shift high low range to neutral before starting.
If the HST is working correctly and the swash plate is in neutral is there any harm in leaving range selector in gear?
Is this in the manual for human safety or tractor protection?
/ How to start HST #2
There is no harm in leaving it in gear but keep in mind that it may have a switch on the Range lever that may prevent you from starting the tractor with it still in gear.
/ How to start HST
There is no safety switch, as I often forget to shift back to neutral since I like to park in gear.
/ How to start HST #4
My Kubota manual says to put the range selector into neutral before starting. It doesn't seem to matter whether I do or not. As long as I have the clutch depressed it will start.
/ How to start HST #5
It's most likely for safety. Many will start the tractor then get off and do something else while it warms up. What's to keep the tractor from taking off if someone (child or whoever) presses a pedal? That could mean instant death of serious injury. Manuals typically don't state procedures without having a reason. More often than not, it's a safety reason.
Best to get into the habit of following the manual. ;)
/ How to start HST #6
I don't have the same type of tractor, but mine will not start if not in neutral. It will also not start unless the parking break is on if my butt is not in the seat. Also having a pto on or engaged will prevent starting. If everything is off, in neutral and the parking break on I can start it standing next to it, which is generally where I am when I start it since I'm going to leave it run at least 10 minutes to warm up before I do anything with it anyway, no sense getting on just to get back off again.
Yes, until you get used to it some of the safety features can seam like a PITA, but once you get used to them you don't even think about it and it all becomes natural. I used to have a small JD lawn tractor, there was a little yellow button on in that you had to press if the PTO was on to go in reverse. Took me all summer to stop mashing my thumb into the dash of the new one every time I went in reverse.
/ How to start HST #7
My 4105 (HST) will definitely not start unless they range selector is in neutral and the parking brake is engaged.
On mine, there is a 'sweet spot' for neutral... on either side of that selector position (High/Low) there are positions where it seems like it's in neutral but it's not. My tractor will not start until I've put it in the correct position.
This is to prevent the tractor moving in case the HST pedal has not returned to it's neutral position.
/ How to start HST #8
my xr4150h will start in gear, without the brake on, and while I'm standing on the ground beside it.
/ How to start HST #9
When I had my MT125, I never shifted the range to neutral. Put 220 hard hours on it, never a problem at all!
/ How to start HST #10
My Kubota booklet also say's to leave in neutral when setting for period (days) of time keep pressure off.
/ How to start HST #12
same with my MT240HE
I did a little test on my MT240He this past weekend. In gear, parking brake not set and no weight on the seat and it started right up. Of course the parking brake not on caused the beeper to start beeping.
I'll have to read the manual again as I was thinking it wouldn't start without the parking brake on.
/ How to start HST #13
I have the gear / shuttle shift version of the MT225E. No seat switch is present at all, confirmed by the dealer. No switch on the brake, so no warning bells. The transmission can be in gear, along with the range selector (the range selector actually does not have a neutral spot). The shuttle shift MUST be in neutral, and the clutch must be depressed (there is a lever to keep the clutch pedal locked down). Those 2 things done, and you can start it standing along side. I was surprised that there are no bells, buzzers, or audible warnings at all! :)
/ How to start HST #14
This is how mine is too. Only, I disabled my beeper... I mean, what beeper? :D
Oh, and my range selector does have neutral. And when I park, I typically make sure everything is in neutral.
/ How to start HST #15
My XR4150 shuttle must have the clutch depressed and shuttle in neutral. Hard to press in the clutch without being in the seat.
/ How to start HST #16
L6060 HST doesn’t have to be started in neutral range.
Long as the pedal isn’t being depressed forward or rear (neutral pedal) and PTO is off, it will start.
/ How to start HST
If forward pedal is engaged but sensor is not, will it be too much load on the starter?
/ How to start HST #18
Not pertaining to this thread, but there is a very simple solution to the 'hard' clutch pedal. There is a single large spring that pulls the pedal up. You are fighting the spring. I have a very bad left knee (bone on bone) and can barely push in the clutch. I was ready to trade the tractor in on an HST and actually was trying to make a deal.
My son (a certified master mechanic and a mechanical engineer) came walking over, looked underneath and said "push in the clutch". He then went to his tool box and brought back a similar sized, but 'softer' spring. He put that one on and again told me to push the clutch....WOW! What a difference! I can actually use the tractor again! You can also easily push in the clutch by hand.
He said as long as the pedal returned fully and was not resting against the linkage, all is good. Try it.....
/ How to start HST #19
The new S-HST's have to be in neutral to start as well.
John Deere Quick Hitch (A64119)
John Deere Quick...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
Caterpillar 416/426/436 Series 1 and 2 Backhoe Service and Parts Manuals (A63117)
Caterpillar...
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
2016 FORD EXPLORER SUV (A59912)
2016 FORD EXPLORER...
