How to Sharpen a Posthole Digger
/ How to Sharpen a Posthole Digger #1
garry
Ohio
JD 1050
I recently purchased a used Husky 3 point post hole digger. It works fine in regular soil but I need to dig some holes in shale. I sharpened the point and that works very well. The cutting teeth just ride in top of the shale. I tried turning the cutting points upside down but that didn't help. so my question is how should I sharpen the the removable cutters. Should I sharpen at a certain angle? Should I sharpen the top side or the bottom side. Should I grind a relief behind the cutting edge? I seems line a waste to buy new points if I have a grinder, I just need to know where to grind. If anyone has a picture of new cutters I certainly would appreciate seeing them.
/ How to Sharpen a Posthole Digger #3
Sharp teeth or not. I wonder if a post hole digger is really designed to bore thru shale.
/ How to Sharpen a Posthole Digger #4
^^^ With no downforce and no impact, I don't see how it would be possible. Hard soil and gravel will stop them. Neighbor tried to dig my red rock gravel with a fairly large tractor and PHD and got nowhere, not even six inches. I had to resort to an air chisel to loosen the gravel and use a manual clamshell to lift it out.
Shale will need to be broken/shattered before it can be removed.
/ How to Sharpen a Posthole Digger #5
Years ago we were holing into North Carolina clay. We lashed a pole on to the boom portion of the post hole digger. That pole extended out to the rear of the digger by about 6 feet. My helper then hung on the pole, giving us down pressure. I don't think that will help with shale.
/ How to Sharpen a Posthole Digger #6
One time I bought a used PHD with a well used auger.. I could not get replacement teeth for that auger so I made homemade teeth out of 3/8" flat stock..
I made several sets that I re sharpened as I could and replaced when necessary... It got the job done..
/ How to Sharpen a Posthole Digger #7
I sharpen all the usual yard, landscaping stuff for some of my neighbors on my block. I wish I could persuade folks to put those implements away properly, instead of leaving them in the weather. I usually scape and oil all the wooden handles, including wheelbarrows, too. It is irritating to find a recently sharpened and oiled spade, with the blade buried in the soil, leaned against the fence. And brooms, resting on the bristles, in the weather. Teeth clencing, growling.
When I was younger, I moved into a new house and put up a fence. Dug about twenty post holes in dry decomposed granite, with a clamshell type. The clamshell was considerably cheaper to rent than the powered auger. But the auger would have made the same twenty holes in a few hours instead of a day and a half. Get a better hole with an auger, too.
/ How to Sharpen a Posthole Digger #8
In CO I would tell you to start with a pick axe (and safety glasses). Wonder if a pick axe will work to break up that shale? Do you need a perfect hole?
MIDDLE BUSTER PLOW (A60430)
MIDDLE BUSTER PLOW...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A60432)
UNUSED RAYTREE...
Butler MFG Water Tanker (A61306)
Butler MFG Water...
78"X16' DOUBLE AXLE TRAILER (A60430)
78"X16' DOUBLE...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60430)
2016 WANCO WTSP...
