How to seal red cedar
/ How to seal red cedar #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Last Friday we cut down a red cedar tree behind my deceased father-in-law's house. I saved several properly sized limbs and want to make coasters from them. These will go to my wife, sister-in-law, and both daughters. What do I use and how do I seal them. Right not the bare wood is sticky with sap when you pick up a piece. The wood is beautiful with a cross section that is white outside and a red inner section.
A few years ago a large walnut tree blew over at my mother's house. I cut several 1"-2" thick 18" diameter sections out of the trunk. My wife sealed them with polyurethane and used them as center pieces on the tables at a lady's luncheon at our church. Since then they have been borrowed and used several times at showers and teas. For some reason the country women in our community love those things. But,....the walnut had none of the sticky sap that the cedar has.
On a side note, I have a partially torn rotator cuff in my left shoulder. The tree had to be cut off at head height as per the contractor's instruction so his small track hoe could get the stump out of the ground. When my wife arrived on the scene I had the chainsaw above my head making the final cut. She was not happy.
RSKY
/ How to seal red cedar #2
I have built several things over the years from Red (airomatic) Cedar and settled on lacquer for finishing. I've always air dried before using but if forced to use green I would try wiping sap off w/lacquer thinner then applying lacquer. I reccomend cutting rounds and air drying as long as you can before finishing. If you have a selection of finishes on hand,do some with water base clear. For coasters I'd steer clear of shellac due to moisture clouding.
/ How to seal red cedar #3
I have used latex paint, parafin wax and bitumen paint to seal end grain to reduce checking/cracking, it prolongs the drying time but worth the wait sometimes, red cedar I am not familiar with so I don't know what it is like for checking.
/ How to seal red cedar #5
The mention of aromatic cedar brought back many old memories. I remember cedar retaining it's enjoyable smell even when dried. Seems a shame to seal it. 😏
/ How to seal red cedar #6
Eastern red cedar dries pretty quickly, especially in smaller pieces. Give it a little time and then use polyurethane - will stay in color from then on. Even the so-called clear liquid preservatives will change the color permanently.
/ How to seal red cedar #7
I'd paint the ends of the limbs, leave the bark on and let sit for a couple years in my hay mow to air dry.
/ How to seal red cedar #9
My entire house is Western Red cedar - inside and out. It's a pre-cut house. Put it together like Lincoln logs. It's a double walled Pan Abode - made in Redmond, WA.
I've tried many different products on the outside. Polyurethane was beautiful but a TOTAL failure. The cedar breathes and the poly ended up creating huge blisters. Log oil looked nice but yellowed with time. Behr was nice but chipped and yellowed with time.
The very best product and what I finally ended up using - InWood semi gloss oil stain. It soaks deep into the cedar, protects it, looks nice and does not have any of the previously mentioned negatives.
I would suggest some "flavor" of oil stain. It comes in many colors - natural, red wood, oak, cedar, etc, etc. Let the oil stain dry for a couple months and then try a varnish product. Being the rounds will be relatively small and should completely dry - they may not blister using varnish.
/ How to seal red cedar #10
Painting,staining,waxing,oiling,coloring and otheriwse obscuring grain and color of Eastern Red Cedar make's as much sense as Scotchgard on tailor made wool Italian blazers. OP live's in and fell tree in Kentucky so it must be an Eastern Red Cedar aka Juniperus virginiana which is among the most beautiful wood in N. America.
/ How to seal red cedar #11
Unless Ea Red Cedar is a whole lot different than the Western variety - the wood must be sealed.
Otherwise - the oils in this beautiful wood will oxidize and the wood will look "telephone pole grey".
You DO NOT necessarily HAVE to obscure the grain and color - just use the correct product to seal the wood.
I speak with forty plus years of experience with a Western cedar timber house.
One of the limbs will be sliced to uniform thickness and made into four sets of coasters for family. For this purpose the wood must be sealed to protect it from moisture. I do want the grain to show so I guess I will do a bunch of experimenting.
The wood also gives off that great cedar smell and some parts will be dried and used in closets to protect clothing from moths.
Son-in-law and brother-in-law have larger thicker logs they have plans for. SIL intends to make a table. BIL wanted a short log that had many, many knuckles from numerous branches, all he will say it that he has a vision.
Wife is still ticked off at me for using the chainsaw with an injured shoulder.
RSKY
/ How to seal red cedar #13
The two spare bedrooms are closed up all the time except when I go in. The rooms still smell of cedar after forty years. Folks who come to the house comment on the smell of cedar.
Every ten years I have a three day project. I rub a clear cabinet oil into all the walls throughout the entire house. This is definitely a late fall project. This oil is specifically made for cedar. With cathedral ceilings throughout the house - this can be an exciting project.
/ How to seal red cedar #14
My comment was with reference to;
I acknowledged the need for and suggested clear coats earlier.
/ How to seal red cedar #15
Try a 60/40 solution of linseed oil and turpentine......works well.
