How to Replace Studs in Bro-Tek Wheel Spacers?
   / How to Replace Studs in Bro-Tek Wheel Spacers? #1
HeLa
Hunterdon County, NJ
Kubota BX25 TLB
I went to remove a rear wheel from my BX the other day and a wheel stud in my Bro-Tek wheel spacer snapped as soon as I applied pressure.
Anyone know:
  1. Can I simply press these from the front side?
  2. Where can I find a replacement?
   / How to Replace Studs in Bro-Tek Wheel Spacers? #2
It does look like a press fit. It should just press out. Did you try to get a replacement stud from Bro-Tek?
   / How to Replace Studs in Bro-Tek Wheel Spacers? #3
That looks like a grade 8 stud. How long was the pipe you had on the breaker bar?
I would suggest emailing Richard at Bro-Tek to see if you can get a new stud.
   / How to Replace Studs in Bro-Tek Wheel Spacers? #5
I've put them in vehicles before. You should be able to drive the old one out and I usually pull the new one in. I usually just use a nut and keep tightening it to pull it tight, sometimes you may have to put a space under it so the lug nut has something to pull against.
ha! i'm guessing a manufacturing defect in the stud. it snapped instantly when applying pressure with a standard 1/2" ratchet.
thanks. i sent him a note in parallel. figured i'd ask here in the meanwhile - always lots of experience on the forum.
   / How to Replace Studs in Bro-Tek Wheel Spacers? #9
Try your local auto-parts store. Bring in the spacer and have them match up your stud.
   / How to Replace Studs in Bro-Tek Wheel Spacers? #10
Following along... See what Richard at Bro Tek says before you take other action. I have 2in spacers on the back and 1.25in on the front of my BX. Great products in my opinion.
2011 Crown Victoria Sedan (A51694)
2011 Crown...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
