How to remove this fuel filter?
   / How to remove this fuel filter? #31
threads like this give me less faith in humanity...
   / How to remove this fuel filter? #32
I have that on my tractor.... I've used a strap wrench for the past five years...no problems getting it off and on.
   / How to remove this fuel filter? #33
It looks so nice and easy until you realize the two rubber lines run right down the ring making spanner or channel lock fit nicely. How'd you make out?
   / How to remove this fuel filter? #34
   / How to remove this fuel filter? #35
Some filters are make so you can use these I
like them. Put your ratchet on cup type and presto
just like removing a bolt
willy
That's great when the part the cup grips is threaded. This one isn't. Good in this instance for breaking the bowl and wadding up the o-ring if you're unlucky enough to have the cup actually fit the bowl.
   / How to remove this fuel filter? #36
I'm guessing the textured ring is unscrewed - is there a tool for this or do I just grab it with some channel-lock pliers?View attachment 712437
Channel locks 1/4 turn counter clockwise. Loosen by hand from there. The cup will likely stick in the housing because the o ring is old and compressed. Don't forget new o ring when reinstalling. Leave the aluminum ring a little loose and turn ignition to prime fuel through the cup. The you can probably hand tighten
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
(6) New 2x15 E-Track Ratchet Straps (A54865)
(6) New 2x15...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2006 Mercedes-Benz R-Class AWD Van (A55758)
2006 Mercedes-Benz...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A56129)
2019 HYUNDAI...
