How to remove fallen tree from pond
   / How to remove fallen tree from pond
I think I'd rent or hire a backhoe if I really needed it out.
Thanks but same problem with backhoe as tractor ... accessibility. Would have to cut down many trees just to reach the location.
   / How to remove fallen tree from pond #12
I would definitely use a snatch block (in addition to your come-a-long) for two reasons, first it will double your pulling power, and you can put the snatch block up high in a tree to help prevent the trunk from digging into the mud.
The other important safety aspect of a snatch block, if you have a catastrophic failure, you won't be in line if the cable snaps.
Like others have mentioned, use rollers of some sort.
Sounds like a lot of work!
   / How to remove fallen tree from pond #13
500' does complicate things.
If there is enough water depth, you could wrap a cable around the tree at the upper end of the trunk and attach that to something large that floats, like a swimming raft, etc. Then use the come-along to apply some lifting pressure to improve the buoyancy of part of the tree. That could help some.
If you could lift it out of the water enough to cut the top of the tree off that would help too. Lift and cut, lift and cut from the water side maybe? Somehow, I can picture a chainsaw going into the pond. :eek: Working from the water end, you have the advantage of some buoyancy.
   / How to remove fallen tree from pond #14
This is going to be a very difficult task. A 3' diameter oak probably weighs 20 tons plus drag from branches in the muck. I think your only chance for success will be to segment before moving. Take every precaution when using a manual come along - failure can be fast and furious.
   / How to remove fallen tree from pond #15
Have you considered leaving the portion you can't reach easily where it is for fish cover? We have several ponds and have left some fallen trees in there to provide shelter. This may or may not work depending on the size of your pond and its intended use.
   / How to remove fallen tree from pond #16
Pics we need pics!
   / How to remove fallen tree from pond #18
Where is the rootball? Is it on solid ground? Are you cutting it off and leaving it in place? I think a come-along is like digging a swimming pool with a teaspoon. It's way, way undersized for the job. You may be able to pull out cut pieces with it, but it's gonna wear you out long before there is much tree moved. Here's a few pictures of the much smaller willow tree I pulled out of my pond. My tractor was spinning and struggling the whole time I was moving the tree.
   / How to remove fallen tree from pond #19
Leave it where it fell. Good for your fish.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
Case Titan 3530 (A56438)
Case Titan 3530...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
