How to remove dashboard sections.
/ How to remove dashboard sections. #1
DEWFPO
"Up High in the Rockies"
2009 Bobcat Toolcat 5600 D
I want to remove the two light gray plastic dashboard sections on my 2009 Series D. I don't see any clips or fasteners above or below. Maybe it's a snap fit. Can someone point me in the correct direction?
Thanks, DEWFPO
/ How to remove dashboard sections. #2
Did you get them off?
No I didn't. I got under there to take another look and it looks like the plastic dash pieces (at least the driver's side) is bolted to metal brackets that bolt to the frame. I only saw one bracket underneath to the left of the steering column, but I'm sure there are more that I just couldn't see. There's got to be an easy way to get it off. It looks **** near impossible and I know that can't be the case.
DEWFPO
/ How to remove dashboard sections. #4
I checked the service manual for my Series F, no mention of the dash. It does show how to remove the black center display panel. There is a tab on each side that you push in while pushing up on the panel.
Why do you need to remove it?
2 reasons. I want to add a new switch to the dash for a back-up camera/monitor and wire it into the reverse circuit. Also, I want to add a voltmeter to the dash.
DEWFPO
UNUSED RAYTREE RMT48 HYD TRENCHER (A65055)
UNUSED RAYTREE...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
SARLO (A64557)
SARLO (A64557)
UNUSED FUTURE P680-HYD BREAKER HAMMER (A65055)
UNUSED FUTURE...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
