How to remove 30" deck drive pully
/ How to remove 30" deck drive pully #1
dlabrie
Campton, NH
Kubota B2910
The pully on my 30" deck separated from its center ring. How do I go about removing when center of it from the shaft?
/ How to remove 30" deck drive pully #2
I'm guessing a pittman arm puller or 3 flange jaw puller would do the trick if it's a press fit. If you have roll pins/or allen head bolts (set screws) in those holes, would need to remove them first.
/ How to remove 30" deck drive pully #3
Even if you just have a propane torch, heat the bottom and get some penetrant in there too. If it becomes too much, cut it w/ a zip wheel while protecting those threads.
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
