How to remove 30" deck drive pully
/ How to remove 30" deck drive pully #1
dlabrie
Campton, NH
Kubota B2910
The pully on my 30" deck separated from its center ring. How do I go about removing when center of it from the shaft?
/ How to remove 30" deck drive pully #2
I'm guessing a pittman arm puller or 3 flange jaw puller would do the trick if it's a press fit. If you have roll pins/or allen head bolts (set screws) in those holes, would need to remove them first.
/ How to remove 30" deck drive pully #3
Even if you just have a propane torch, heat the bottom and get some penetrant in there too. If it becomes too much, cut it w/ a zip wheel while protecting those threads.
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2022 Caterpillar 262D3 (A64126)
2022 Caterpillar...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
