How to release hydraulic lines
   / How to release hydraulic lines #1
Rally Farm
Catlett
1995 JD 6400
I know this is a dumb question but I just bought this property which came with a 95 JD 6400. I don't have a manual yet and have never owned a tractor before. It has a MX 15 attached and I don't know how to disconnect the lines going to the bush hog. Looks like something needs to release the ball bearings inside the socket. Any help would be appreciated. Thank you.
-Lance
   / How to release hydraulic lines #2
There are no dumb questions. ;)
You just slide/push the outside ring that captures the ball bearings towards the tractor. Do the opposite to reconnect the coupling.
video..(listen carefully due to the Indian accent which makes you feel like you are at Motel6 or have a computer question)..
https://www.youtube.com/watch?v=HyUuOUDMKms
:welcome: to TBN
Thanks, I'll try that.
   / How to release hydraulic lines #4
Make sure you lower it down all the way first, or you will have a hard time getting the lines to reconnect afterwards.
Aaron Z
I'm not sure where the ring would be on these? download_20150618_120159.jpegdownload_20150618_120213.jpeg
It's obviously something simple and I don't see it so its killing me. I will have to go into hiding after I find the answer.
   / How to release hydraulic lines #6
I suspect that the ring is what the flip up cover mounts to
Aaron Z
So just pull hard on the hose to remove it?
   / How to release hydraulic lines #9
Awesome, thank you.
2014 Nissan Pathfinder SUV (A53117)
2014 Nissan...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
Epic Electric Cart (A51694)
Epic Electric Cart...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
