4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,958
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I'd agree with #5 to a point. If the well can recharge at the same rate or faster than the pump can pump, it shouldn't make a difference until you get past the water level in the ground. The extra HP would only make a difference to get the water past the point of the water level to the surface, wouldn't it?
So maybe the deeper the surface of the aquifer, the more HP would be required to lift it to the top of the well casing.
I'm sure there's something I'm missing there.
Yes if the pump was set in 70 foot of water the difference in power to pump it that 70 foot would be very minimal. But you would still need to size your pump to pump it 70 more feet through air. Why else would you set the pump that deep in water if you weren’t planning on the water dropping?
