How to operate rotary cutter
   / How to operate rotary cutter
But my question is still...is it better to have it set up to operate with the 3PH all the way down or slightly raised? Doesn't all that weight and bouncing around harm the seals/hydraulics if it's not all the way down?
   / How to operate rotary cutter #13
The tractor is supposed to and should hold up the front of the mower. It was designed to work that way and it won't hurt it in any way.
   / How to operate rotary cutter #14
   / How to operate rotary cutter #15
</font><font color="blue" class="small">( But my question is still...is it better to have it set up to operate with the 3PH all the way down or slightly raised? Doesn't all that weight and bouncing around harm the seals/hydraulics if it's not all the way down? )</font>
No it doesn't hurt it to have it up a little. The hitch is made to handle it, Look at it this way, a 1200 pound backhoe riding around on a 3PH and it doesn't hurt it, I don't think your brush hog will.
I have a round bale speer I put on the back of my 354 and haul round bales 1300lb ones everyday.
What damages your hydraulic lift is lifting to high (stops not set right) and the sealing oring runs past limit and pops out of the lift cylinder past the limit of travel, even at that its not a big deal to fix, just messy.
   / How to operate rotary cutter #16
   / How to operate rotary cutter #17
On the Jinma 200 series there is a hydraulic safety valve located between the 3PH control valve output and the 3PH lift cylinder. If you try to lift too much weight or apply too much weight to the 3PH lift mechanism such as when bouncing a heavy impliment, the excess hydraulic pressure this will cause will be vented back to the resovoir and the impliment will lower. That is of course providing that the safety valve is set to the correct release pressure.
   / How to operate rotary cutter #18
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
Towable Diesel Generator (A59228)
Towable Diesel...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
PENDING SELLER CONFIRMATIONS (A59575)
PENDING SELLER...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
