HOW TO MOVE A DEAD TOOLCAT
   / HOW TO MOVE A DEAD TOOLCAT #11
timm9,
That would be great. The primary dimensions I am interested in is the overall length of the bolt (measured from under the head to the end) and the length of the portion that doesn't have any threads on them. I think I can figure out the thread size once I have an opportunity to remove the existing threaded plugs.
   / HOW TO MOVE A DEAD TOOLCAT #12
Steiner5,
Here's what I have come up with. Hope this helps;
Length overall including Head is 75 mm
Length of bolt from bottom of head to point is 68 mm
Length from bottom of Head to last thread is 38 mm
Diameter at threads is 12 mm
Length from last thread to tapered point is 29 mm
Diameter of smooth shaft between threads and taper is 9mm
Length of last taper is 12 mm
   / HOW TO MOVE A DEAD TOOLCAT #13
What thread pitch?
   / HOW TO MOVE A DEAD TOOLCAT #14
just let the scrapper either put it on the wrecker with a tow line, or, just cut it up in place, and put the now lighter weight parts in the truck, I don't see the need to go through such a big hassle!..
   / HOW TO MOVE A DEAD TOOLCAT #15
timm9....Thanks for all of the measurements. This will make it easy.
ruffdog.... when I get a chance to get back to the machine, I will measure the thread pitch of the existing plugs.
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
LINCOLN ELECTRIC POWER WAVE 455M WELDER (A57192)
LINCOLN ELECTRIC...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
Forestry Truck Grapple and Frame (A55852)
Forestry Truck...
Elgin Pelican Street Sweeper (A55851)
Elgin Pelican...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
