HOW TO MOVE A DEAD TOOLCAT
/ HOW TO MOVE A DEAD TOOLCAT #1
Jabonee
Pennsylvania
Mahindra
You can't!:laughing: Just kidding. you can but it requires some knowledge and tools. 2 things need to be done to allow the unit to be moved no matter what model you have. Release the brakes and allow the oil to move in the drive circuit. Releasing the brakes is done by using a porta power and applying pressure to the front and rear brake hoses at the brake valve. Remove the hoses from the valve and tee them together with the porta power. 100psi should do it. Releasing the drive is a little more involved. 2 choices. If your model allows you to access to the F and R relief valves you can pull them. It will make a mess when you move the unit. I like to just unbolt the drive motors and slip the back a little just enough to disengage the drive gear. its less messy and you don't have to disconnect any hoses.:thumbsup:
/ HOW TO MOVE A DEAD TOOLCAT #2
What I would try:
Buy a used long box plastic bed liner and cut it in half lengthwise. Jack up one side of toolcat and slide half of bedliner under the tires...do the same for the other side.
On the front of the bedliner, put one 2x4 on the inside, one on outside and bolt together so it ties both sides together (down in the front bottom corner area).
Put chain on 2x4s and toolcat......SKID it.
/ HOW TO MOVE A DEAD TOOLCAT #4
Jaonee,
I like your idea for disengaging the drive motors. Especially because it doesn't require opening any hydraulic lines. The model I need to move is a B series so it has the ability to install the bolts to release the brakes. Do you or anyone happen to know how long the bolts are that are used to release the brakes?
5600 brake tool.PNG Not sure of the size. 3/8??
/ HOW TO MOVE A DEAD TOOLCAT #7
Yes, I have the photo from the manual also. My plan was to remove the existing plug and match the threads to a longer bolt. The only issue is I don't know how long the bolt is in the photo. I guess I could try to scale its length from its diameter.
/ HOW TO MOVE A DEAD TOOLCAT #8
If we knew if it was a 8x1.25 or a 10x1.5, you could scale the thread pitch to the bolt length.
Try probing the depth with a screw driver once you have the plug removed.
/ HOW TO MOVE A DEAD TOOLCAT #10
If helpful I have a set of the Bolts to disengage the axles and will measure them tonight after work and post back here. Unfortunately I have a Council of Governments meeting tonight so I won't be home until after about 10:00/pm.
/ HOW TO MOVE A DEAD TOOLCAT #11
timm9,
That would be great. The primary dimensions I am interested in is the overall length of the bolt (measured from under the head to the end) and the length of the portion that doesn't have any threads on them. I think I can figure out the thread size once I have an opportunity to remove the existing threaded plugs.
/ HOW TO MOVE A DEAD TOOLCAT #12
Steiner5,
Here's what I have come up with. Hope this helps;
Length overall including Head is 75 mm
Length of bolt from bottom of head to point is 68 mm
Length from bottom of Head to last thread is 38 mm
Diameter at threads is 12 mm
Length from last thread to tapered point is 29 mm
Diameter of smooth shaft between threads and taper is 9mm
Length of last taper is 12 mm
/ HOW TO MOVE A DEAD TOOLCAT #13
What thread pitch?
/ HOW TO MOVE A DEAD TOOLCAT #14
just let the scrapper either put it on the wrecker with a tow line, or, just cut it up in place, and put the now lighter weight parts in the truck, I don't see the need to go through such a big hassle!..
/ HOW TO MOVE A DEAD TOOLCAT #15
timm9....Thanks for all of the measurements. This will make it easy.
ruffdog.... when I get a chance to get back to the machine, I will measure the thread pitch of the existing plugs.
2007 Ford F-150 Pickup Truck (A64194)
2007 Ford F-150...
Wooden rocking horse (A64557)
Wooden rocking...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A64553)
2025 58in Padfoot...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
