Loader how to measure a fel capacity
   / how to measure a fel capacity #11
sdkubota said:
Explain the overall bucket width in feet and inches. Then describe with as much detail a cross section of the end of the bucket like depth, height, and if the top also has a small width or it comes to a point in inches. You do that and I will tell you what it holds.
Better yet, draw a diagram of the side of the bucket, and write down the measurements of every edge. Scan and post it here. We know your width.
If you don't have a scanner,take a picture then post the measurements here starting at the top and going clockwise around the end of the bucket.
Either way, having a visual reference with accurate measurements will give us the info needed to provide you with an exact calculation.
The bucket width is 4' 6 1/2" left to right. The depth 22 inches. The height (from cutting edge to top is 30 inches. The cross section has six different angles with a total measurement of 85 inches all around if that helps any. I also attached two pics. Thanks for your help.
   / how to measure a fel capacity #13
I threw the picture on an estimating program I have. Based on what I have to go on, a struck bucket is 2/3 cubic yard (.66) (18 cubic feet)
A heaping bucket (again - this is a guess), but based on my program - 22.5 CF or .83 cubic yards.
Hope this helps.
   / how to measure a fel capacity #14
Fill it with water, one 5-gallon bucket at a time. Convert gallons to cubic yards. Yeah, it'll take a while, but then you'll know.
Alternatively: measure the flow rate of your garden hose by timing how long it takes to fill a 5 gallon bucket. Take several measurements to ensure you're accurate. If you are on a well, run the hose for a few minutes before measuring, to make sure you've exhausted the pressure in your reservoir and are running 100% off your pump. (Usually, I can see/feel a small drop in pressure when this happens.) Then time how long it takes to fill your bucket and multiply by the flow rate.
   / how to measure a fel capacity #15
13 and 1/2 bags of 2cu ft mulch = 1 yard.
3/4 yd = 20.25 cu ft
1/2 yd = 13.5 cu ft
Depmandog, somehow or another with my assbackwards math I got .83 as well so I'll just call it 3/4 of a yard. I liked the idea of dumping into the wheelbarrow also. Thanks to everyone for your help on this.
   / how to measure a fel capacity #17
Use water - see how many gallons the bucket holds then convert to cubic feet. A gallon is .1333 cubic feet. Estimate "heaping" from there.
   / how to measure a fel capacity #19
If u could be certain a bag of mulch from the store was accurate, you could empty bags into the bucket to determine the cubic feet. That would be apples to apples, as it were. :)
An unedited/uninterupted video of said test, could be shown to any customers who question your claim of bucket volume.
You could even post it on YouTube as an advertisement and cool proof.
   / how to measure a fel capacity #20
Fill a 5 gallon bucket with water TIME it exactly.
You will end up w/ 5 gallons in "X" amount of time.
Now w/ the exact same hose flow and with your FEL
bucket LEVEL so you can hold as much water as possible,
fill the FEL bucket and time it.
Now just do the math, Online Conversions, Unit Conversions is awesome.
Bush Hog 15' Batwing Mower (A57149)
Bush Hog 15'...
Yale Warehouse Forklift (A57149)
Yale Warehouse...
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
Fork Extensions (A57149)
Fork Extensions...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2014 Timpte Hopper Bottom (A56438)
2014 Timpte Hopper...
