How to maintain wooded walking trails
   / How to maintain wooded walking trails #12
If I want to open or pack my trails - a pass or two with my ATV. If I wanted to get fancy - reverse my rear blade and pack the snow down.
   / How to maintain wooded walking trails #14
Just a data point; Sport sleds are not made for work and go slow. They use a tunnel heat exchanger which do not get enough snow on them when you go slow and pull implements.
   / How to maintain wooded walking trails #15
Just a data point; Sport sleds are not made for work and go slow. They use a tunnel heat exchanger which do not get enought snow on them if you go slow eought to pull things.
agree at 100% but if there is 3 to 4 inch powder then it will be ok and for short distance it is fine even on snow pack but yes you need to keep a eye on the temperature.
   / How to maintain wooded walking trails #17
Some of us are quite serious about grooming trails and done it for many, many years. :D😁🤣😁
This is our personally owned machine.
A trail Bully 400
Various sleds over the years I've used.
   / How to maintain wooded walking trails #18
I have tried with an RTV900 (no tracks) and you'd have to be out there before it got really deep. I would set the plow up a bit and go, but often get stuck as I'll drive up on a drift and not know it until I sink in. With the tractor I have done it using 3 skidsteer tires bolted together in a V with an eye-bolt to hook it to the tractor.
   / How to maintain wooded walking trails #19
I’d guess that a roller of some kind might do the best job of packing the snow hard enough that it doesnt just form a crust that collapses under weight of someone.
   / How to maintain wooded walking trails #20
Yes, a roller thats a bit wider than your tow machine and does not stick to snow. That would be HDPE plastic. It would look like this.
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2022 Case IH Steiger 470HD AFS Connect Quadtrac 4WD Tractor, (A50657)
2022 Case IH...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
1995 FORD DUMP TRUCK (A51222)
1995 FORD DUMP...
