How to maintain wooded walking trails
   / How to maintain wooded walking trails #12
If I want to open or pack my trails - a pass or two with my ATV. If I wanted to get fancy - reverse my rear blade and pack the snow down.
   / How to maintain wooded walking trails #14
Just a data point; Sport sleds are not made for work and go slow. They use a tunnel heat exchanger which do not get enough snow on them when you go slow and pull implements.
   / How to maintain wooded walking trails #15
Just a data point; Sport sleds are not made for work and go slow. They use a tunnel heat exchanger which do not get enought snow on them if you go slow eought to pull things.
agree at 100% but if there is 3 to 4 inch powder then it will be ok and for short distance it is fine even on snow pack but yes you need to keep a eye on the temperature.
   / How to maintain wooded walking trails #17
Some of us are quite serious about grooming trails and done it for many, many years. :D😁🤣😁
This is our personally owned machine.
A trail Bully 400
Various sleds over the years I've used.
   / How to maintain wooded walking trails #18
I have tried with an RTV900 (no tracks) and you'd have to be out there before it got really deep. I would set the plow up a bit and go, but often get stuck as I'll drive up on a drift and not know it until I sink in. With the tractor I have done it using 3 skidsteer tires bolted together in a V with an eye-bolt to hook it to the tractor.
   / How to maintain wooded walking trails #19
I’d guess that a roller of some kind might do the best job of packing the snow hard enough that it doesnt just form a crust that collapses under weight of someone.
   / How to maintain wooded walking trails #20
Yes, a roller thats a bit wider than your tow machine and does not stick to snow. That would be HDPE plastic. It would look like this.
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55314)
2023 New Holland...
(2) GMC Top Kick Transmissions (A54865)
(2) GMC Top Kick...
378257 (A54865)
378257 (A54865)
SDLanch SDLD25 (A53316)
SDLanch SDLD25...
EZ GO Electric Golf Cart (A53314)
EZ GO Electric...
