How to install a rear remote on a Kubota B2320?
   / How to install a rear remote on a Kubota B2320? #1
waggy5
New York
Kubota M7040 & B2320
Hi Folks, how do you install a rear remote on a Kubota B2320? I have 2 fittings from the dealer. he pointed at the locations where they go, but, any assistance would help. I have the remote and the hoses.
thanks
   / How to install a rear remote on a Kubota B2320? #2
Without more info or research it is hard to say...usually there is an adapter that connects to the pump body that you run your hoses from...those hoses will need to connect to a SCV ...then you run other hoses to quick disconnects...
   / How to install a rear remote on a Kubota B2320? #3
Is your B set up for a BH like my BX? If not you will have to find the three lines, Power, Tank, and Power Beyond and use a valve assembly w/PB connection. Other wise nothing else will work when the rear remote is operating. If I do not maintain the PB circuit with the BH off, my 3 PT and FEL do not work. Get the Workshop Manual and you can trace out the hydraulic circuit, they are only $90. I am in the planning stages of building a large log splitter and will use the 3 BH line connection points for my splitter circuit, I will also have a log lift and hoist incorporated into it.
Ron
   / How to install a rear remote on a Kubota B2320? #4
I thought about it, read the instructions and decided it was better to pay the dealer whatever he wanted to do it for me. Didn't take very long and didn't cost very much. well worth it for the little things that can go wrong and the learning curve required.
I found out it takes 2 special fittings and goes where a BH would be plumed. once I had the fittings it was no big deal making up the hoses. The tractor was supposed to have it mounted when I bought it.
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
