How to ID axle rating...??
   / How to ID axle rating...?? #1
/pine
Super Star Member
I inherited a single axle 6'x12' trailer...How can I determine the weight rating on the axle?
   / How to ID axle rating...?? #2
The bearing combination will determine the axle rating but I don't know if there is a chart listing it. ??
   / How to ID axle rating...?? #3
Check the bearings.
How many lug is it?
Check the bearings.
How many lug is it?
5 lug pattern...What do I check the bearings for?...inside (shaft) diameter?...what is it about the bearings that equate to the rating?
Thanks...
   / How to ID axle rating...?? #6
Typical Axle Ratings Based on Axle Diameter | etrailer.com
Here's a breakdown on typical axle weight ratings based on axle diameter:
1,000-lb - 2,000-lb Axles: 1-1/2" - 1-3/4" diameter
3,500-lb Axles: 2-3/8" diameter (Can have a 3-1/2" diameter, but rarely)
6,000-lb - 7,200-lb Axles: 3" diameter
8,000-lb Axles: 3-1/2" diameter
9,000 lb Axles: 4" diameter
10,000-lb Or more axles: 5" diameter
Bruce
   / How to ID axle rating...?? #7
If it's 5 lug and the axle is over 2" it's more than likely a 3500# axle.
To be sure you need to check the inner and outer bearing and race numbers.
Chris
   / How to ID axle rating...?? #8
It should be 3500lbs
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
