How to ID axle rating...??
   / How to ID axle rating...?? #1
/pine
Super Star Member
I inherited a single axle 6'x12' trailer...How can I determine the weight rating on the axle?
   / How to ID axle rating...?? #2
The bearing combination will determine the axle rating but I don't know if there is a chart listing it. ??
   / How to ID axle rating...?? #3
Check the bearings.
How many lug is it?
Check the bearings.
How many lug is it?
5 lug pattern...What do I check the bearings for?...inside (shaft) diameter?...what is it about the bearings that equate to the rating?
Thanks...
   / How to ID axle rating...?? #6
Typical Axle Ratings Based on Axle Diameter | etrailer.com
Here's a breakdown on typical axle weight ratings based on axle diameter:
1,000-lb - 2,000-lb Axles: 1-1/2" - 1-3/4" diameter
3,500-lb Axles: 2-3/8" diameter (Can have a 3-1/2" diameter, but rarely)
6,000-lb - 7,200-lb Axles: 3" diameter
8,000-lb Axles: 3-1/2" diameter
9,000 lb Axles: 4" diameter
10,000-lb Or more axles: 5" diameter
Bruce
   / How to ID axle rating...?? #7
If it's 5 lug and the axle is over 2" it's more than likely a 3500# axle.
To be sure you need to check the inner and outer bearing and race numbers.
Chris
   / How to ID axle rating...?? #8
It should be 3500lbs
John Deere (A50322)
John Deere (A50322)
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
