How to ID axle rating...??
   / How to ID axle rating...?? #1
/pine
Super Star Member
I inherited a single axle 6'x12' trailer...How can I determine the weight rating on the axle?
   / How to ID axle rating...?? #2
The bearing combination will determine the axle rating but I don't know if there is a chart listing it. ??
   / How to ID axle rating...?? #3
Check the bearings.
How many lug is it?
Check the bearings.
How many lug is it?
5 lug pattern...What do I check the bearings for?...inside (shaft) diameter?...what is it about the bearings that equate to the rating?
Thanks...
   / How to ID axle rating...?? #6
Typical Axle Ratings Based on Axle Diameter | etrailer.com
Here's a breakdown on typical axle weight ratings based on axle diameter:
1,000-lb - 2,000-lb Axles: 1-1/2" - 1-3/4" diameter
3,500-lb Axles: 2-3/8" diameter (Can have a 3-1/2" diameter, but rarely)
6,000-lb - 7,200-lb Axles: 3" diameter
8,000-lb Axles: 3-1/2" diameter
9,000 lb Axles: 4" diameter
10,000-lb Or more axles: 5" diameter
Bruce
   / How to ID axle rating...?? #7
If it's 5 lug and the axle is over 2" it's more than likely a 3500# axle.
To be sure you need to check the inner and outer bearing and race numbers.
Chris
   / How to ID axle rating...?? #8
It should be 3500lbs
1014 (A51573)
1014 (A51573)
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
SKID STEER BUCKET (A52472)
SKID STEER BUCKET...
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A51572)
2000 Isuzu NPR-HD...
JLG ELECTRIC MANLIFT (A52472)
JLG ELECTRIC...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
