Security & Theft How to deter theft - how about this idea
   / How to deter theft - how about this idea #31
Thanks for all of the replies. I think I have come up with a solution. I am planning to build a 10x16 pole shed to keep it in (gable roof, totally enclosed) and just get insurance.
That way, a locked barn will probably keep out kids and vandals, and if a thief gets after it, that will be covered by insurance.:rolleyes:
Thanks again.
Joseph
Smart move.
   / How to deter theft - how about this idea #32
I would be as worried about kids/morons dumping sand etc in the fuel or oil fill holes.
These machines are not like full size constuction equipment where all that type of stuff is lockable.
On one of the jobs I was on, kids dumped sand in an excavator engine and hydro tank, the machine ran a couple of minutes before things started to go very wrong.
The owner lost the key years ago so he never locked the fuel/oil caps.
After he had it flushed and repaired he got new locks and keys.
Another favorite up here is throwing rocks thru the glass, most all the construction machines that are left on the jobs all have removable glass shielding of some type.
We've seen most of this ..match sticks stuck in tyre valves,Oil drain plugs loosened,Water in fuel tanks..kids can be very thoughtful.A lot of the crews i've worked on have stopped locking doors and windows ..if they are going to steal a $100 stereo it's not worth $600 for glass as well.
   / How to deter theft - how about this idea #33
Can someone explain how tractor insurance works?
Premium - $250
Deductable - ?
What's covered - ?
For example, is it covered if something falls on it like a tree branch in winter storm or if god forbid it catches fire? What if this happens at my buddies house when I leave it there overnight to do some work for him?
How do they determine replacement value if stollen?
Thanks,
Joel
   / How to deter theft - how about this idea #34
Thanks again.
Joseph
Joseph, just to add another thing to think about. It sounds like the property you have is not where you live and does not have any structures on it at this time. If you add a shed or any structure it could change your status with the insurance company as far as liability insurance goes. It did for us and we had to take down an old hunting shack to get liability insurance. It may also change your situation with the tax man. Just some things to check into.
MarkV
   / How to deter theft - how about this idea #35
G'day teg over here we do have tractors painted pink and when they first come out they could not get enough to keep up with demand they were NH Boomers and they were painted pink in support of breast cancer :):)
Jon
   / How to deter theft - how about this idea #36
Insurance is your best bet.
best theft deterant is you setting on it with a gun.
past that.. just like you were told... someone who REALLY wants your tractor will get it.
a roll back truck and a pair of bolt cutters, a small torch set, or a battery powered abrasive blade /angle grinder will cut 99% of just about anything you can put on her.
rolloff don't care about missing batteries, no key.. no starter.. tires.. fuel cutoff.. etc.
it's sad but true.
soundguy
Hello everyone,
I am new to this forum. I am about to purchase a new JD 50hp machine and will be keeping it in a rural location. I have been going back and forth on how to secure it from theft.
I checked into insurance and it is $250/year for a 14K machine through my insurance company which seems very high (I plan on shopping around more next week).
So, I have been trying to figure out how to best secure it. I thought about all the usual ignition/starter/fuel disable schemes, until I talked a fellow at a dealer who basically blew all my theories.
He told me that a person from my home town had just had his tractor stolen with a bunch of disable stuff in place. I asked him how and he told me the thief fed it ether through the intake and got it to fire enough to get it on a trailer, while shorting from the battery to the starter terminal (bypassing any anti-theft circuits on the starter side or fuel system side).
So, after hearing this, I realized that there is no way to disable the fuel or ignition system (besides maybe taking the starter home with you). Not to mention the risks of someone just winching it up without starting it.
So, I have come up with some ideas to prevent theft. I was hoping folks could provide some feedback as to whether or not I would be wasting my time:
1.) Park it in the woods, out of sight from the road.
2.) Rig the back and front tires out to row crop width to keep it from easily being loaded on a standard lowboy trailer.
3.) I designed a bracket made out of 1/4" plate that will securely hold the front axle in place. The brackets will look like an upside down "L" and allow the tractor to be backed into place. The "L" will have another hinged "L" piece that will lock into place with a standard lock. The trick will be that the 2nd hinged piece will have a 1/4" plate protection box where the lock will be that only has a hole big enough to insert your fingers and key to unlock it and loop it in and out of the catches within that box (that way the lock is protected from bolt cutters, grinders etc). The whole assembly will be anchored in concrete that goes several feet deep. That way, the thief will basically have to bring a torch to the site to cut through the brackets (will have one on each side of the front axle between the wheel and engine).
Any opinions on my ideas?
Thanks,
Joseph
   / How to deter theft - how about this idea #37
I vote for the insurance, definitely the cheapest way to go.
Nothing is gonna stop someone from doing what ever they have to do to defeat your efforts, especially if it is so remote.
Some one mentioned the GPS idea, all the expensive construction equipment has it now, had a boom lift on a job and moved 1/2 mile down the street for some side work and the rental company knew it.
Get a sticker that states there is some kind of built in tracking system on board, that may be enough to discourage would be thief's.
JB.
   / How to deter theft - how about this idea #38
This could work :D:D:D
   / How to deter theft - how about this idea #39
I was on a job one day when a rollback pulled up. The driver was with a JD dealer/service. He was to pick up a JD skid steer that had rubber tracks. The contractor did not leave the keys as he was supposed to do. The driver did not have JD keys. He said no problem. He just hooked the cable to the skid steer and drug the machine up onto the rollback. That's a lot of dead weight. No problem. He had it loaded in a few minutes.
I'd go with the insurance, too.
2013 Dorsey Pitts 48ft. 40 Ton T/A Flatbed Equipment Trailer (A60460)
2013 Dorsey Pitts...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Unverferth Roadrunner 536 Head Cart (A59814)
Unverferth...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
