How tight are your chains?
/ How tight are your chains? #1
Gobblin Tom
Western, PA
2011 JD 2520
The dealer took my tractor the other day and added the chains to the rear wheels. They have a little slack in them and are not hitting anything, not sure if I should use bungees and tighten them some? The ride definitely got a lot worse!!!!! They are some serious chains.... My other garden tractors or quad I always kept them pretty tight.... I am just looking for some input on what people do with their tractor chains???
/ How tight are your chains? #2
My 4 link ladders are very snug and I use binders to keep 'em tight.
I can lift the crosslinks an inch or two off the tread, but they aren't loose at all.
Per the folks at tirechains.com, loose chains wear considerably faster...
/ How tight are your chains? #3
You will get both sides of the equation, some like them loose. I am at the other extreme, I make them as tight as possible, even the extra loose links I zip tie so you can't here any loose chain.
Some say you don't need tensioners, I don't agree and use at least 4 point slack take up between the side chain.
JB
/ How tight are your chains? #4
I put mine on as tight as I can get them. Then I drive around a bit and tighten them again. As long as the spring tensioners stay tight from that point, I'm happy.
Joe
/ How tight are your chains? #6
I don't keep mine tight, and don't put any of the bungees on either.
If the chains are cut to fit the tire, then no need for bungees to take up slack that shouldn't be there in the first place.
Some tire chains just come close to fitting, and are often oversize for the specific tire size.
But I've no problem with someone wanting their chains tight tight. ;)
Just we don't all think that is the best way.
/ How tight are your chains? #7
Tom,I don't think its a good idea on the 2520 to have them loose.The clearances are just too close for comfort. Mine fit very tight,where I probably don't need to bungee them,but I do anyway. I'll try to get some pics.
Same here,I don't like anything flopping around.
Greg
/ How tight are your chains? #8
Greg
The clearances are much better if you have the tires in the wide position.
/ How tight are your chains? #9
I have a 2305 and I tighten the chains as much as possible, drive around with them for awhile and then retighten them and then add a couple of bungee cords. Even with all this, I usually have to retighten them a couple of times over the winter. BTW I have filled tires so they don't deform a whole lot.
They are in the wide position already. My chains are not all that loose but I can hear them jingle a little bit. I'm thinking I better get the bungees out... Does anyone bungee the inside of the tires along with the outside?
/ How tight are your chains? #11
I keep them tight as possible. Have learned they will eventually come off if loose. Also will come off using tensioner springs.
There are many factors involved such as the type of tire, clearances, type of ground surface, sharp turns, amount of use, etc. Best thing to do is just try different things until you find the right combo for your situation. The main thing to avoid is having the chains hit your tractor and causing damage.
/ How tight are your chains? #13
If your tires are not loaded let the air out, fit your chains tight then blow the tires back up.
Dan D.
/ How tight are your chains? #15
I followed tirechains.com video and mine are very tight...no slack at all. I also use spring binders. They work GREAT
/ How tight are your chains? #16
Joe
Ditto. I like 'em snug and work to get the inside link tight, then the outside, then the tensioners with a ratchet, and re-tighten after running around a bit. I cable tie loose ends. I pluck the tensioners all winter.
My nightmare is that the chain slips off and wraps the axle, although I've never read any chain failure stories. That said, I think the real key is to have right sized chains to start with. If they are, it's hard to figure how they'd slip off and it seems like the tensioners are just taking up slack so the things don't rattle around so much.
/ How tight are your chains? #17
I'm another "righty-tighty" chain guy! I've found that whenever the going gets tough.. and you're having to work the tractor to get out of a bad spot - you don't want the chain or chains coming off!
Nothing is worse than being stuck and having to dig the wheels out to reattach the chains!! :mad:
I'd rather dig balled up hay outta a baler when it's 105F in the shade than crawl around in a frozen snowdrift trying to get a 150lb chain back on the wheel!!
AKfish
/ How tight are your chains? #18
I have just ordered a John Deere 1026r which is 4 wdr. Question. Not having received the tractor or owner manual, can I put chains on it?
2024 Schulte 5026 Batwing Rotary Cutter (A63118)
2024 Schulte 5026...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2020 International MV607 Cab and Chassis Truck (A61568)
2020 International...
2021 Dodge Durango SUV (A61569)
2021 Dodge Durango...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2000 Ledwell 48ft. Step Deck Trailer (A64047)
2000 Ledwell 48ft...
