How often do you change anti-freeze on Kubotas?
   / How often do you change anti-freeze on Kubotas? #21
Every 3 years, or more if it's in a dusty environment.
May I ask what bearing "dusty environment" has to do with life of anti-freeze in a sealed by radiator cap cooling system?
Thanks,Jim
   / How often do you change anti-freeze on Kubotas? #22
Thanks,Jim
Depends on the system, if it has a separate expansion tank that is open to atmosphere then in very heavy dust applications I can see it contaminating the system.
A lot of the newer systems have a sealed expansion system and shouldn't have any issues with dust.
   / How often do you change anti-freeze on Kubotas? #23
Do a dc voltage check to check the condition of your antifreeze , (Google it )most of these compact tractor have a parent bore diesel engine a coolant system flush and replace with a coolant like Peak Final charge would be just fine....if you happen to have a wet sleeve engine a more robust antifreeze would be in order
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
2019 Deere 35G (A53317)
2019 Deere 35G...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
John Deere 5100M (A53317)
John Deere 5100M...
532 (A52708)
532 (A52708)
2021 KOMATSU PC88MR-10 EXCAVATOR (A52709)
2021 KOMATSU...
